Timer recording, more than 1 show
I have a Sylvania 6260VF VCR. I have not been unable to tape more than 1 show at a time. If I program on #2 nothing will tape, not even what is programmed on #2. I have tried it when something is set on #1 and when there isn't. I just bought it and it's rather anoying. I'm not sure if I should be doing something else, or it just doesn't work right.
Thanks for the help.
I have no solution how to fix it. My idea is . Use the One-touch timer Recording (OTR) on page 27.
If your manual is the same as mine. My VCR recorder is broken.
Posted on Sep 11, 2008
Old tapes recorded wont track speedup slow down
Hello; This can be a very complicated issue. The simplest, is a dirty control track head located on the output (or right side of the drum containing the video heads). It is just before the pinch roller. Clean well with isopropyl alcohol 91%. The second likely thing is a damaged tape, that has a creased bottom edge caused by a defective VCR that has excessive reel takeup torque that causes this tape to crease while playing it. Open the cassette door where the problem is and check the tape for a bottom crease. usually about a crease 1/32 of an inch or more from the bottom. Tapes that are creased cannot be saved. John
Dec 15, 2010 | Sylvania 6260VF VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Get nothing but static when i turn it on
make sure you go from the cable box were it says out to the in on the vcr from the vcr you want to come out to the tvnow you can program the the vcr to pick up the cable chanell from the boxthe vcr has to be on chaell 3-4 in the front were it shows what chanell your on then the tv and the vcr are to be on the wright cahells the tv has to line up with the chaell your useing for the vcr3-4 to make this less complicated put a tape in the vcr hit play if its playing you are on the right chanel you do not have to have the vcr to watch cable it will go threw even if vcr is off just have to be right chanel
May 18, 2010 | Sylvania 6260VF VCR
Govideo model dv2130
You should be able to get into a list of timer recordings by this method:
1 Open “Initial Setup” menu
Press the SETUP button or the TIMER button while the DVD is in
Stop or Play mode.
2 Select “PROG”
Use the ??/?? buttons to highlight “PROG” then press the
ENTER button.
3 Select the recording to be deleted
Use the ?? and ??/?? buttons.
Press the ?? button to move to the next setting.
The squares are the arrow keys! You should be able to delete the settings using these keys or some other key.
Next time you set a timer recording make certain you don't set the weekly setting!
Apr 29, 2010 | GoVideo Go Video DVD/VCR Combo
How to record on vcr/dvd combo I set the timer program to record on the vcr but nothing happen, I can record by hitting the record button, but unable to get the timer to work. I received the vcr/dvd combo...
First make sure the internal clock is setup correctly observing am/pm. Then try recording something so you can watch the operation to see if it works. Make sure you have a tape you can record on and also make sure the write protect tab has not been removed from the front lower corner of the tape. Good Luck! I hope you now have success!
Nov 11, 2009 | Toshiba Televison & Video
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
Sylvania SRD4900 DVD/VCR combo problem
Hi I am Temperance MI and I see this mode in my shop often, does any onscreen menu come up when using the remote and
going into menu? If not maybe the remote is bad, common just
a loose battery lead, If you are able to go into menu, and set the
clock, but unable to set timer record, look closely at you recordable tape to make sure on the left bottom from corner the
the recording tab is in place, You can place scotch tape over this hole of existing tab to ensure it will go into record. Finally
if it wont go into record when you try to use OTR, you
make a problem with the record ready switch in the VCR section. Joe . East Electronics, Temperance MI
Jan 23, 2008 | Durabrand DUR7 Portable DVD Player
Record
i have uploaded the user manual for this model, it should be visible within the next 24 hours. the quick version is this:
if you haven't done so yet, set the clock
menu/ use up/down arrows to select "clock set", press right arrow to select, set day, year, etc using up and down arrows, when each is set, the right arrow moves you to the next bit
once clock is set
timer recording
menu
use up and down arrows to scroll to timer recording, and press the right arrow to select
set the program number (1-8)
set frequency (once, daily, weekly)
set the date to record
set start time (i usually go 5 mins prior)
set end time (i usually go 5 mins after)
set channel number
set tape speed
exit by pressing clear/c reset
press t-set to activate the timer
the timer rec light should come on, the timer recording will not be active unless you press the t-set button
hope this helps
trin
Nov 16, 2007 | Sylvania SRD3900 DVD Player/VCR
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
