Question about Canon imageRUNNER 400S Copier
Error code
I have ir 2016j indicating E805, what is the cause and the solution
  • unclesam Aug 30, 2008
    pressed reset button
    Problem Solver:
  • 6 Answers
805 codes are usually associated with fixing exhaust fans not powering up. Usually due to a blown SMD (Surface Mount Device) fuse on the DC controller PCB.
Posted on Aug 31, 2008
How do i fix Error E007 on Canon IR 2016j?
Replace the fixing film assembly or fixing film.
Mar 15, 2015 | Canon Office Equipment & Supplies
The heat discharge cooling fan failed to function. Problem is usually resolved by replacing the bad fan motor assy. If not, the DC power supply is probably bad.
Dec 03, 2014 | Office Equipment & Supplies
Ir 2020 e805
E805- Fan Failure- open rear cover find PSU and check for rotation of cooling fan at power up ( spins as soon as display lights up)
If it isnt spinning - replace with correct part from Canon, the circuit is expecting a feed back specific value which will only be seen with the correct fan.
Jan 16, 2014 | Office Equipment & Supplies
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Dec 21, 2013 | Canon imageRUNNER 400S Copier
In canon ir 2016 there is no scanner movement & also the laser lamp is not glowing & the machine is indicating check document
In canon IR 2016j, if you get error " check document", its a communication error. so you check the flat cables in control board ( is a board in the scanning section)
* Change cable from scanning lamp
* change 2 cables from ip board.
Jun 12, 2012 | Office Equipment & Supplies
Canon ir400 E0805-0014
this is not the same sub code but it's a start.
getfile.asp?rid=1258 September 27, 2002 getfile.asp?rid=3215 Product : imageRUNNER 330 / 400 Title : E805-0002 Error Code Error :
E805 with a 0002 Sub Code
Workaround :
This may be caused by a pinched wire that goes to connector J108 B-18 on the DC Controller. The wire was pinched to the frame near the riser to the DADF-A1 exit side hinge. Inspect the harness indicated by the arrow in the picture. getfile.asp?rid=4772 Canon USA, Inc. Systems & Technical Support Division
Dec 28, 2010 | Canon imageRUNNER 5570 Copier
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
E805 error in canon ir 400
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Jul 21, 2009 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
208 people viewed this question
old marine
old marine
