Question about LG Washing Machines
Outside of drum has four spring-action plastic cylinders which are attached with metal bars to drum and washer casing. The center of 2 of these cylinder/tubes has popped out and the metal bars have broken. How can I find replacement parts? LG top loader, portable washing machine, model # WF - T8501TP
  • ChaSquiggy Aug 29, 2008
    Partselect.com does not carry LG parts. It may also be helpful if someone could tell me the technical term for the parts I need.
    Thanks for the info! I'll have to get the model number at home before I can be sure that I can find the parts. But, knowing what I am looking for is helpful.
    Brigadier General:
  • 3,614 Answers
There was no replacement part for that.. if it the drum guider was the one broke, there was no replacement fort that, unless fabricate it..
Posted on Aug 29, 2008
    Master:
  • 521 Answers
Complete details and all the queries for ur machine are mentioned on the link below to guide u completely step by step
http://www.applianceaid.com/washers.html
pls do rate the solution
thanks.
regards.
fixya expert team
    Genius:
  • 1,269 Answers
There's a contact number for your model on the manual that came with your unit. Better check it there..
For the manual and technical parts, click the link below
http://ca.lge.com/en/down/product/050406/WF-T8501TP/WF-T8501TP_V4.pdf
  • LG Master
  • 19,396 Answers
  • Ginko
    Ginko Aug 29, 2008
    The small springs are called structure springs, the bigger cylindric joints are called strut assembly.
    If it is a LG you can buy parts at repairclinic:
    Repair Help
    You will need to input correct model number (the one on service tag ) to find parts.
Front loader washing machine inside hard plastic bar broke off
there are several kinds of plastic cement..everything from superglue to plastic pipe cement like plumbers use..available at most hardware stores..even model glue..I would try one of these before pitching the washer..you nmay be able to screw it on using stainless steel sheet metal screws also..
Jan 15, 2014 | Kenmore Washing Machines
The drum has moved forward, it works great but the water appears to hit back of drum and splashes every where. The drum is not centered when its not running leaning forward. I found a thin long spring not...
Hi, That spring you found it could be holding the drum in place. Open the back and see where it could have come off. When they move the machine it might have sprung out. Good luck.
Oct 13, 2011 | Kenmore 24032\24036 Top Load Washer
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
Replacing the rear drum brakes cylinder
remove upper shoe return springs, loosen but do not remove brake line using line wrench, remove 2 bolts holding cylinder. Have new cylinder ready to install. pull shoes back from cylinder. remove line from cylinder and pull out of housing. Replace with new cylinder, first attaching line, then bolts. reset shoes into cylinder and make sure nothing else has slipped out of place (eg, parking brake cross bar and spring). Replace return springs on post. replace drum. open bleeder valve and allow gravity bleed until all air is out or bleed manually. any questions, lemme know.
Sep 05, 2010 | 1994 Pontiac Grand Am
Turned washer on started to agatate made loud squilling noise
Hi, Check inside the drum for loose plastic bars that help tumble the clothes. If you can shake them, open the cabinet top and tighten the bar screws on the outside of the drum. If any appear stripped and don't tighten, remove the bar from the machine and inspect for cracking around the screw holes. If found, replace with new parts. Otherwise, try breaking off matchsticks in the holes and see if the screws will tighten. The top is either held on with screws in the back--then slide the top backwards to remove, or there is a pair of spring clips in the front corners that require a thin putty knife to be slid into each clip and pushed until the clip releases. The back end of the top usually has plastic hinges and won't come entirely free of the cabinet. Hope this helps!
Take care
Jun 13, 2010 | Maytag SAV2555A Top Load Washer
Change drum brakes
Brake Shoe: Service and Repair
REMOVAL
1. Raise vehicle and remove rear wheels.
2. Remove and discard spring nuts securing drums to wheel studs.
3. Remove brake drums.
NOTE: If drums prove difficult to remove, retract brake shoes. Remove access plug at the rear of backing plate and back off adjuster screw with
brake tool and screwdriver.
4. Remove U-clip and washer securing adjuster cable to parking brake lever.
5. Remove primary and secondary return springs from anchor pin with brake spring pliers.
6. Remove hold-down springs, retainers and pins with standard retaining spring tool.
7. Install spring clamps on wheel cylinders to hold pistons in place.
8. Remove adjuster lever, adjuster screw and spring.
9. Remove adjuster cable and cable guide.
10. Remove brake shoes and parking brake strut.
11. Disconnect cable from parking brake lever and remove lever.
INSTALLATION
1. Clean support plate with brake cleaner.
2. If new drums are being installed, remove protective coating with carburetor cleaner or brake cleaner.
3. Clean and lubricate anchor pin with light coat of Mopar multi-mileage grease.
4. Apply multi-purpose grease to brake shoe contact surfaces of support plate.
5. Lubricate adjuster screw threads and pivot with spray lube.
6. Attach parking brake lever to secondary brake shoe. Use new washer and U-clip to secure lever.
7. Remove wheel cylinder clamps.
8. Attach parking brake cable to lever.
9. Install brake shoes on support plate. Secure shoes with new hold-down springs, pins and retainers.
10. Install parking brake strut and spring.
11. Install guide plate and adjuster cable on anchor pin.
12. Install primary and secondary return springs.
13. Install adjuster cable guide on secondary shoe.
14. Lubricate and assemble adjuster screw.
15. Install adjuster screw, spring and lever and connect to adjuster cable.
16. Adjust shoes to drum.
17. Install wheel/tire assemblies and lower vehicle.
18. Verify firm brake pedal before moving vehicle.
Aug 12, 2009 | 1997 Jeep Cherokee Country
On a flat floor but bangs and crashes when spinnig. Also the drum wobbles.
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
"whole new machine" per technician-STILL shakes uncontrollably
I had the same problem. I fixed it but not sure how long it will last. There are two load balancing springs one on either side of the drum. In my case one of them was apparently assembled without the plastic bushing where it attaches to the frame of the washer. This caused the spring to wear a slot all the way through the sheet metal and fall off. This left one spring attached pulling the drum to one side causing an unbalanced load. I ordered a new plastic bushing and spring online for about $40 for both. I then used JB Weld to fill in the gap where the sheet metal was worn through then reassembled with new parts. Been fine now for about 6 months.
Mar 24, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Shipping bolt installation
A total of four shipping bolts need to be installed: two longer ones on the bottom and two shorter ones on the top. Each shipping bolt consists of a metal screw inside a plastic cylinder which fits between the washer suspension and the back of the washer cabinet. The metal screw pulls the washer suspension against the plastic cylinder which, in turn, is pulled against the rear cabinet, thereby securing the suspension against the back of the cabinet. The Whirlpool part number is 285955. These bolts can be ordered from various suppliers for $20 - $30. To install these bolts, you will need a 13 mm wrench and a flashlight so you can see where the bolts screw into on the washer suspension.
The procedure is as follows:
1. On the back of the washer, remove the 4 plastic covers over the oblong shipping bolt holes. Carefully pack these covers with the water and drain hoses as they will be needed when the washer is re-installed in its new location.
2. Using the flashlight as a visual aid, look inside the oblong holes and identify the area on the washer suspension into which the shipping bolts screw. It is a white plastic part that is not directly behind the the shipping bolt holes, but is slightly above that level.
3.Look at the shipping bolts. The bolts described above (Part number 285955) have a a plastic arm at one end . This arm must be sawed-off for installation on older machines. You will have to determine whether or not the arm needs to be removed.
4. Starting with the bottom two holes, carefully slide a shipping bolt through the hole toward the front of the machine. Angle the bolt upward toward the screw mating hole, and carefully guide the bolt into the hole. Use the 13 mm wrench to engage the bolt into the mating hole.
5. Make sure that the plastic end of the bolt is closely seated against the back of the washer cabinet. Using the 13 mm wrench, screw in the lower two bolts, but do not tighten at this time.
6. Repeat steps 4 and 5 for the upper two shipping bolts.
7. After the plastic part of all 4 bolts has been firmly seated against the back of the washer cabinet, carefully tighten all 4 bolts.
8. Go to the front of the washer and push on the drum. The drum will rotate but it should not rock. If that is the case, then you are done.
Feb 29, 2008 | Washing Machines
Washing Machines Logo
271 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
