Question about Black & Decker Power To Go Cordless AC/USB Power Supply (CPI20XB) 20-Watt Power Supply
Power indicatoror how do i know that my power to go is fully charged.
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Posted on Feb 27, 2009
How to CHARGE CORDLESS DRILL
First, you should know your battery is a Ni-CD / NI-Mh or Li-ion battery. If it is a Ni-CD / NI-Mh battery, please fully discharged and fully charged it to prevent "Memory effect".
If it is a Li-ion battery, please charge it before you use it.
Please keep in mind that, please fully charge a battery when you store it. And, charge it again every two months.
If your old battery is dead, you can replace it with a new one. Ryobi Power Tool Battery
Oct 05, 2014 | Drills
Quingo plus taking 30 minutes to power up and only lasts about 4 miles, when fully charged
Hi, can you please explain by the term takes 30 minutes to power up ?
Do you mean once you turn it on , it takes 30 minutes before it lights up ?
Regards
Rob
www.gewizrepairs.co.uk
Feb 28, 2014 | Pride New Mobility Legend 4 Wheel Scooter
I have Norelco 6867XL. After fully charged, my razor will lose all power one day after. I don't know what happens. Can you help me resolve that problem. Thank you.
the battery of your Norelco 6867XL is weak and cannot hold charge for long any longer. The cell in the battery as become very weak such that it cannot hold charge for a very long time anymore. This it why it looses power one day after it is fully charged.
Have the battery replaced and problem should be solved.
I hope you understand the above, if you don't please let me know for further assistance.
Regards.
Aug 11, 2011 | Norelco Quadra 6867 XL Electric Shaver
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
I have ER224 RC hair trimmer, I have been charging this for 2 days, it's led is still RED, i dont know if it is fully charged yet or not? is the led green for fully?
some devices doesn't have indicator that it is already fully charged so my advise is since almost all rechargeable gadgets needs to be charged 4-8 hours depending on the power needed by the device for example a cellphone that uses 37 volts li-ion battery should be charged 3-4 hours to use it in its maximum capacity. so look how much power needed by the device and charge it at least 4 hours for the battery to be full.
Dec 17, 2010 | Panasonic ER224
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
How to know if the battery is fully charge?
While charging your psp battery if power light no longer flashes orange then the battery is fully charged......
May 30, 2010 | Sony PlayStation Portable (PSP) Console
Mv acer aspire 3623WXCi turns off when i unplug the power cord with battery attached, is the battery dead and do i need a new one?
when you plug the power cord check and see if the battery shows that its charging ,if the charge level is low allow it to charge fully ,after its fully charged remove the power cord and see if it will go of again .if it goes off then you know the battery is dead if not it might be of low charge or not properly fixed.hope this helps
Sep 17, 2009 | Acer Aspire 3623WXCi (NBACERC1500XX1) PC...
Battery is fully charged but it still wont power up no lights when plugged in to charge
Hook up only the ac adapter to the DS to see if it turns on. If it does then we know the ac adapter works. We know the battery got fully charged but the system isn't turning on with the battery that is fully charged up.
I would say your battery is defective but you won't really know until you fully charge up a known good working battery and test it out.
Jun 29, 2009 | Nintendo DS Lite Console
IBM T40 the battery is fully charged but will not power on with the ac
Have you disabled your battery
is your battery showing
check control panel\power options
does your battery show as 100 % charged
then you can also check device manager for battery
Let me know
Jan 29, 2009 | IBM ThinkPad T40 2373 Notebook
Black & Decker Power To Go Cordless AC/USB Power Supply (CPI20XB) 20-Watt Power Supply Logo
551 people viewed this question
Top Black & Decker Computers & Internet Experts
Vuk B
Are you a Black & Decker Computer and Internet Expert? Answer questions, earn points and help others
