Question about Combi Centre DX - Mango
Ariston Microgenus 27mffi combi boiler
My boiler has an intermittent fault. The hot water and heating just stops working for no apparent reason then after either a few hours or days it starts again. I've contacted an engineer but by the time they can come to look for the fault, the boiler is working again and they said if it's working they wouldn't be able to find the fault! I've contacted Ariston but they told me to call out an engineer. I'm getting very frustrated with this. There are no warning lights when the fault happens and I've looked through the manual to try and get some idea. Do you think it could be the pump getting stuck or do you have any other ideas? Thank you for your help.
  • loaff Feb 10, 2009
    I have an Ariston Microgenus 27 mffi combi boiler with the intermittent problem mentioned by others.
    16 months ago I had a new pcb, 2 new thermistors and a new air pressure switch fitted ( in fact 3 pcbs as 2 failed immediately ! ).
    Fine until a month ago when the intermittent working/not working started again, sometimes heating, sometimes water, sometimes neither and sometimes both.
    I asked a different Corgi plumber to check. He contacted Ariston's tech depatment who told him to replace the pcb, thermistors and air pressure switch.
    Surely new replacement parts should last longer than 16 months ! However, Ariston churned out the mantra that their product has a 2 year guarantee. I argued that all the replaced parts were their products.
    Isn't thei a legal answer to this clearly flawed product ?
    Clearly their is
  • punjabimu670 Apr 15, 2009
    my boiler show chek flow failed
    Problem Solver:
  • 7 Answers
Im an engineer and recently had exactly the same thing with this ariston boiler, i found out it was the the 'air pressure switch', this is a switch which is part of the ignition, it works in conjuction with the fan. when the boiler fires up the air pressure switch makes, if its faulty it can break the circuit mid flow and cause the burner to shut down therefore giving intermittent hot water and heating, theres a possibility that the aps tubes may be damaged as well so ensure they'e condition is good. hope this helps you
Posted on Sep 18, 2008
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Ariston microgenus he24 fault is e34 but boiler works when front cover is removed
e34 on a ariston is the fan. Boiler fires up with cover off as its getting the air it needs from atmosphere! fan is not running at full speed
Nov 04, 2011 | Combi Centre DX - Mango
My ariston micro genus type c boiler keeps going hot and cold, the heating also switches on and off, any ideas
when was it last serviced?dirt may be a factor,there are many parts that cause this fault in the microgenus so you need someone familer with the product parts playing up could be1.airswitch2motor3flowgroup4ntc you havent mentioned if it needs re-setting
Jan 10, 2010 | Combi Centre DX - Mango
Ariston Gas Boiler error code E02 what is the problem. No other boiler specification on the type of boiler.
i belive you have a ariston microgenus 2,from memory thats the fault code for low water presure,you need to re-presurise to 1 bar
Nov 27, 2009 | Ariston Technologies AWD 121
MicroGenus27 No Hot Water
check HW and CH temperature probes check secondary heat exchanger for blockage check water pressure switch
Jan 03, 2009 | Combi Centre DX - Mango
Boiler flames extinguish and reignite regularly
what about flame rectification probe (flame proving probe)
Nov 30, 2008 | Combi Centre DX - Mango
Ariston combi boiler
sounds like your diverter valve is passing on the boiler, this diverts the heat either to the rads or to the taps, if its passing through the heating chanel it'll heat up the rads- may also be a scaled up secondary heat exchanger, hope this helps you
Aug 21, 2008 | Combi Centre DX - Mango
I have an Ariston Microgenus 27 Combi Boiler
I hate these boilers!
If the pump is not circulating change it. If the pump is ok you may have a blockage in the diverter valve
Apr 04, 2008 | Combi Centre DX - Mango
No hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Feb 18, 2008 | Washing Machines
Combi Centre DX - Mango Logo
3,675 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
