Question about Maytag MER5775Q Electric Kitchen Range
Right front burner not functioning properly
My right front burner will only work on the "smaller" setting. When it is switched to the larger burner setting (on which I always use it), it still only heats up the smaller coil. Any suggestions?
  • amerwit Sep 24, 2008
    Thanks for the input! My husband was able to open the top of the range, and found that the burner (on the outer part) was fried, causing the short. We ordered a new part (the element) for about $50 or $60, and now it works perfect. Thanks again. The article was informative. (My range is fairly new).
  • 750 Answers
Hello amerwit
Hello ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Sounds like you have a bad switch that needs to be replaced in your electric range!
How old is this range?
You will need a good service tech, hands on for this!
Let me know how it goes,
Huuum
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old range
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your range,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your ranger is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of ranges you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 24, 2008
My burner gets excessively hot very quickly is this normal?
That right front burner is an extremely hot burner by design. It is sold as a quick power burner. The rating on it is 12,000 btu's meaning it could easily boil a pot of soup in that time.
Here is a quote from the owners manual for your range
"There is a 12,000 BTU*
burner located in the right front position. These burners offer
higher speed cooking that can be used to quickly bring water
to a boil and for large-quantity cooking."
Use the back for slower smaller cooking and front for larger and quick heating.
I hope that helps.
May 09, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
One burner does not work. The outer burner works, but smaller inside one gets no power. It is only 2 years old
I called Maytag and even though my warranty had expired, they offered to fix it for free. What a nice thing to do!!
Oct 08, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
GE JBP69
Replce infinite switch.
Jul 18, 2008 | GE JBP69 Electric Kitchen Range
Gas range top burners hard to light...
Gas burners use propane or natural gas...refer to the manual to see what it takes and sometimes you have a switch to select the proper gas. you can call a gas man to confirm this and correctly tell you whats going on. but he will propably make a trip. good luck
Aug 31, 2007 | Kitchen Ranges
Maytag MER5775Q Electric Kitchen Range Logo
156 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
