Question about Mr. Coffee FTX24 12-Cup Coffee Maker
After filling my Mr. Coffee to the 12 cups limit, turning on the machine...2 1/2 cups of water do not make it to the pot. There is NO water on the counter but the poor thing is steaming like a locomotive (steam engine train). I ran vinager & water solution through 3 X's to no avail. Now it is putting out less and less water than before.
  • Anonymous Feb 17, 2009
    Reservoir still has about 6 cups left in it unbrewed yet machine beeps that it is done and stops brewing. Turned pot off and back on and then it sounded as if it were brewing again , yet just a few drops of water every 5 or 10 minutes brews. Aggravating!
Hi, My husband found the problem and fixed it. Something had fallen into the water reservoir and was small enough to block the pump. My husband extracted it, now all is well. the Coffee Maker is fine now.
sincerely,
chalice (a.k.a. HolyGrail56)
Posted on Aug 30, 2008
My Mr. Coffee is taking over an hour to brew a pot of coffee
Run a half a pot of vinegar through it then 2 or 3 pots of water. It's from lime and calcium deposits.
Nov 05, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
Why does my Mr. Coffee pot fill and overflow with more coffee than the 12 cups of water that was put I the reservoir?
Looks Mr Coffee has a matter generating hability., defying basic laws of the universe. Kind of a "Little Bang Theory". Seriously, no, it has no secret water compartment. Possibly some water remaining there from previous use.
Jun 24, 2015 | Mr. Coffee Coffee Makers & Espresso...
How do you make coffee with Mr. Coffee, Jr. 4-cup automatic coffee pot?
Its pretty easy to open the top and fill the reservoir with water up to the level needed (i.e. 4 cups). Then press the ON button to start the brewing process. Make sure you fill the filter with ground coffee.
See the following link:
Mr Coffee Coffemaker
Apr 13, 2015 | Coffee Makers & Espresso Machines
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
How do you clean this product using vinegar?
Put a small amount of vinegar in the coffee pot, fill with water "12 cups" add contents to main unit and turn on, when finished! empty pot in sink and refill coffee pot with water only and cycle it through three to four times to make sure the vinegar is flushed out of the lines, adding fresh water each cycle.
May 19, 2011 | Mr. Coffee 12-Cup Programmable Coffeemaker
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
How to clean a coffee pot with viniger??
Try 1 cup viniger fill rest of pot with water. run it through the machine. through away fill pot with water run through 2 more times. that should do it.
Apr 23, 2009 | Mr. Coffee TFX20 / TFX23 Coffee Maker
Not getting all the water
its most likely evaperating cheaper models are known for this!
Dec 09, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
More Steam Less Coffee
I had same problem after 4 months. very slow brew time, 10 cups of water poured in made about 6 cups of coffee. I used a packaged coffee pot cleaner powder and this fixed the problem (for now).
Dec 26, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee FTX24 12-Cup Coffee Maker Logo
411 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
