Question about Dryers
Indesit is60vu dryer is not heating up - Dryers
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
This sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 Theheating elementscan fail (meaning open circuit)
2 There arecut-outs (T.O.C's)that might need resetting
3 Thethermostats (stats)can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors andpcb's (Printed circuitboards)thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Posted on Jan 10, 2010
  • apart4u
    apart4u Jan 10, 2010
    sorry here is the video
    You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
  • 550 Answers
Most common cause is burn out of the thermal cut-out. These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
Clean the exhaust ducts all the way to the outside wall, lots of vent hoods block over time. then examin the exhaust duct for devices that look like this Indesit is60vu dryer is not - 01fa8b4.jpg or like this 20fceaf.jpg with wires connected to the terminals. there may be 2(hi lo), test with a flashlilight bulb or meter conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 29, 2008
How do I change the thermostat on an Indesit IDC85
heater units have 2 or 3 starts ,check they work ..on some hotpoint dryers there is a stat on the front top right just under the timer as wire burns out then no heat ..WARNING TAKE OUT THE PLUG
Sep 16, 2015 | Indesit IDC85S Silver Electric Dryer 8kg,...
Indesit wd125 - everything works but the dryer doesnt get hot - wont dry
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;';
Jul 19, 2011 | Indesit Dryers
Indesit condensor tumble dryer does not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 08, 2011 | Indesit IS70C Electric Dryer
My indesit dryer is IDV65, the drum is spinning but the dryer is not heating up and the clothes are still wet.
heatman101
Jan 05, 2011 | Indesit Dryers
Reset on indesit dryers not heating
heatman101
Nov 01, 2010 | Indesit IS70C Electric Dryer
I have just bought an Indesit tumble dryer model no IDC75, the dryer is working ie the drum is moving but there is no heat being generated from the machine
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Indesit Dryers
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Indesit Dryers
No heat in indesit dryer. cycles as normal
Hi
remove back panel and with a mulitmeter check the stats to see if open circuit if so replace and should be back to normal.
regards
Mar 12, 2009 | Dryers
Dryers Logo
145 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
