Question about HP iPAQ H2215 Pocket PC
Synchronization error Out of the blue, my pocket pc will not synchronize with my desktop. It sits looking for changes and finally errors out. Any suggestions? I'm running with activesync 3.8...
    Master:
  • 450 Answers
First try soft resetting your Ipaq, and restarting your PC.
Posted on Sep 11, 2005
Hp touchsmart 300
From the User Guide at... http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4174137&
The wireless keyboard and mouse are pre-synchronized, for your convenience, to work with your
HP TouchSmart PC. The keyboard and mouse should work immediately after you pull the battery tabs to
activate the preinstalled batteries, and then turn on the mouse (A).
You may need to manually synchronize the wireless keyboard or mouse if they are not functioning.
To synchronize them:
Make sure the keyboard and mouse are next to the HP TouchSmart PC, within 30 cm (1 foot) and
away from interference from other devices.
Keyboard: Press the Connect button on the bottom of the keyboard (B) for five seconds. The blue
activity LED on the wireless receiver illuminates when the synchronization command has been received
and turns off when synchronization is complete.
Mouse: Press the Connect button on the bottom of the mouse (C) for five seconds. The blue activity
LED on the wireless receiver illuminates when the synchronization command has been received and
If this does not work, remove and then re-insert the wireless keyboard and mouse receiver from the back of
the computer and then synchronize the keyboard and mouse again.
Fr
Jun 30, 2014 | Computers & Internet
Microsoft Activesync not working properly
Have you tried synchronizing it to a new outlook profile?
Jun 17, 2008 | Microsoft Computers & Internet
Afico 2035e - error SC326
326 C 2nd laser synchronization error
The 2nd laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
• Poor connection between the laser
synchronization detector board and
the LD unit.
• Laser synchronization detector board
out of position
defective
• LD unit defective
My guess is that polygon mirror failed £50 -£60 if u brave enough to change it yourself
if not its lazer or sync board
Nov 08, 2010 | Ricoh Aficio 1035 Copier
I get an intellisync error 0x8004fd28 when trying to Sync my blackberry
Hi, When attempting to synchronize between the computer and the BlackBerry smartphone, the Error 0x8004fd28 message appears on the BlackBerry Desktop Manager. This is due to the intellisync folder is corrupted. To resolve this issue, you need to complete the following steps: 1. Close BlackBerry Desktop Manager. 2. On the computer, navigate to the appropriate folder listed below: · If you are using Windows® XP, go to C:\Documents and Settings\\Application Data\Research In Motion\BlackBerry\Intellisync · If you are using Windows Vista?, go to C:\Users\\AppData\Roaming\Research In Motion\BlackBerry\Intellisync Note: If you are unable to view the above folder refer to additional information section on instruction on how to view hidden files 3. Delete the Intellisync folder. 4. Open the BlackBerry Desktop Manager. Note: If the BlackBerry Desktop Manager attempts to synchronize at this stage, synchronization will fail. 5. Configure the BlackBerry Desktop Manager for synchronization by completing the following steps: a. Click Synchronize. b. Click Configuration. c. Click Synchronization. 6. Synchronize calendar appointments. OR If there are one or more corrupt entries on the BlackBerry smartphone . Take back up and clear the database on the BlackBerry smartphone. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Error downnloading URL erros occured while windws was synchronizing
If you receive an error message telling you: Errors Occurred While
w
indows Was Synchronizing Your data chances are you tried to add a
c
hannel to your Active Desktop while not connected to the Internet.
to r
esolve the problem, log on, right-click the Desktop, select Active
d
esktop, then choose New Desktop item. Type in the site's URL,
and
online content will stream to your Desktop
Jun 09, 2009 | Microsoft Windows XP Media Center Edition...
Error 608
You must reinstall the software from your device. switch it off from the power button and then back on with the joystick pressed down.You will have a blue screen. Put inside one sd-card formatted in fat16 file system with the rom named as winceimg.bin ( you will find it on google).Choose winceimg by sd/mmc card by pressing joystick center. Wait untill on the display will write "restart your device". This will solve your problems
Mar 06, 2008 | Mitac Mio 168RS GPS Receiver
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Sep 12, 2005 | Palm Treo 650 Handheld
Why does pocket mirror trawl through all items when synchronising a calendar
The HotSync software on the Mac was never designed to cope with the scenario where you synch with a PC elsewhere. It assumes that you are performing a recovery synchronization when it sees that the handheld synched elsewhere. The assumption with the Palm OS was always that you synched one computer to one PDA. With more propsperous times, the software has not yet evolved at Palm Source (not part of Palm Inc any longer.) With regards to PocketMirror, there is a setting to allow you to synch to more than one PC. The setting is buried deep in the PocketMirror settings for each of the four conduits. The setting allows PocketMirror to see more than one PC as your route to an Exchange server.
Sep 11, 2005 | Palm Zire 71 Handheld
Errors sync with Outlook 2003 and Tungsten T3
I did search through the forums before posting and the only "solution" I found was to buy Chapura PocketMirror for $30 which I refuse to do. I should be able to sync this palm with Office without having to spend even more money.
Sep 11, 2005 | Palm Tungsten T3 Handheld
"Communications Error 608"
If you put the Toshiba Pocket PC e740 in your USB Cradle you may receive a "Communication Error 608". This is not a serious error, it is just a false setting in the ActiveSync Program. Please follow these steps below to correct this problem: "Tap" on start and choose the ActiveSync program Then "tap" on "Tools" and choose "Options" in the ActiveSync Program Check under "Enable synchronization when cradled using" to see if the setting is on "USB" If it is set on "Bluetooth", please change it to "USB". Now you can close the application window Important: Please remove the Pocket PC from the cradle and then return it to the cradle. This activates the new setting Important to note: This above described issue occurs if you "tap" accidently on the Bluetooth Icon in the Program Group or activate Bluetooth of any other reason, the ActiveSync Option will be set to "Bluetooth" instead of "USB". This setting will cause the "error 608" if you put in the Pocket PC e740 in the Cradle and start to synchronize over USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
HP iPAQ H2215 Pocket PC Logo
78 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
