Samsung AW1203B Air Conditioner Logo
Posted on Jul 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My air conditioner worked fine last night, but when I tried to turn it on today in the 101 heat, it displayed E1 (blinking). I've unplugged it because it would not let me turn it off either.
Anonymous
Level 3:
  • Master 2,006 Answers
  • Posted on Jul 22, 2011
Anonymous
Master
Level 3:
Answers
2006
Questions
Helped
593207
Points
6261
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced
Air conditioning inverter large unit.
Can only but try this.Generic Procedures for Clearing an E1 Error
  1. Turn off the air conditioner and unplug it.
  2. Hold down the power button, and keep it depressed while you or someone else plugs it back in. ...
  3. Unplug the air conditioner again and plug it back in.
  4. All best to you from Clive
What is tgm inverter error code e1
Robert Moller have the answer. Thnx Mr. Moller.
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
1helpful
Displays "E1" and resetting the
I have just moved in to a flat with a vent axia storage heater. I switched it on last night and although the output in off it is still heating up the room today. Is that normal? thanks Heather
Yes, Heather, it's working correctly. It lives up to it's name "storage heater". When you turned it on last night, it heated and at the same time it was storing heat to be used later, during peak electrical use hours, without having to use any electricity. It's working as it should.
Hope this helped you and thanks for choosing FixYa.
2helpful
2answers
Haier Air conditioner problems - e1 message
try turning it off holding buttons each individually in for 3 secs then in an hour plug back in ... the rep from Haier gave me this advice ... just waiting my hour now ... i also hear that the remote works for sure ...
19helpful
3answers
E1 error code on air conditioner
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
My electronic panel will not work at all.
This is not the most technical of solutions, but I had this exact same problem last night and I unplugged the air conditioner and left it that way overnight and this morning it had reset and was working again. I had tried everything I could think of to get it to work prior to just letting it be overnight. Hope this works for you, as well.
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
