Question about Compaq EVO T30 Network Terminal
Removing password on T30
I have a numberous compaq T30 thin clients connecting to Microsoft 2003 Terminal Servers. I have an automatic logon,
When I am hit the esc key, prior to the automatic logon, the user name and password prompt window appears for the admin logon.
I do not know the admin password, so I am stuck!!
Is their a way to reset the t30 back to factory defaults by booting to a flash image configuration?
Please let me know
thanks
Jim
  • Odinfo Jan 30, 2009
    I have the same problem, the thin clients were once connected to a (now) dead server and I need to reset them to configure on the new server, haven't found anything in the various PDFs on compaq website.
  • 24 Answers
YES.... providing that the hard drive was not completely re-formated before the windows OS was installed.
Usually, manufacturers leave a section of the HD for this so in the event that something goes wrong, you would be abke to revert back to the manufacturer's setup.
Simply follow the following instructions... :
1) remove power from the T30.
2) hold or tap the 'G' key on the keyboard
3) apply power back on T30 while maintaining step 2)
4) turn on T30 via power button while maintaining step 2)
5) T30 should eventually boot up and in factory default settings.
If this doesn't work, repeat process or the T30 was configured to disable the 'G' key. In this case you need to reflash the firmware on the T30.
Posted on Jun 29, 2009
Smartcard cannot be forwarded to Terminal Server via RDP
Try re-registering the services on the client computer and see if that fixes it. Otherwise I would consider reinstalling Windows on the client.
Feb 11, 2014 | Microsoft Windows 7 Professional 64 Bit 3...
How do you connect ethernet so you have both your desktop and thin client connected?
Purchase a ethernet hub. I have 1 by Linksys. They are relatively inexpensive. Plug your cable modem into the uplink jack and your desktop and anything else to the other ethernet ports.
Char S.
May 20, 2009 | Compaq Evo Thin Client T30 (311335-001) PC...
I have mtnl garuida -fw modem, but i have no driver for this, so plz tell me how can i download driver, from where???????or what is link
elaine.teleport.com/%7ecurt/modems.html
www.drivershq.com/drivers
www.k56.org
www.itu.ch
www.chipset.com
TYPE IN THE FOLLOWING INFORMATION IN THE ADDRESS BARS:
HP COMPAQ EVO T20 NETWORK TERMINAL DOCUMENTS
HP COMPAQ EVO T20 NETWORK TERMINAL DRIVERS
HP THIN CLIENT T5135 NETWORK TERMINAL DRIVERS
HP THIN CLIENT T5135 NETWORK TERMINAL DOCUMENTS
HP THIN CONNECT RK271AA#ABA DOCUMENTS
HP THIN CONNECT RK271AA#ABA DRIVERS
HP E104
HP DK407AABA
HP 700/70 DRIVERS
HP 700/70 DOCUMENTS
HP 700/70 INFORMATION
I HOPE THIS CAN HELP YOU, BUT I MAY OF MADE MORE WORK THAN HELP
CANDYMANGANDY
Mar 07, 2009 | Computers & Internet
Neoware ca5
True, even if you reflash the system to bring it to a fresh state, it will still need a server to do anything reasonable.
Head over to http://www.neowareftp.com/ and click on the "Tech Support" link. A password dialog box will show up: [since it may violate TOS here I won't post that info, but it's readily available on the web.] Once in, click on the FlashRecovery link, then pick the flash that relates to your machine - CA5's are usually the CE versions. Download the file.
Now, this program will work on XP systems. Install the program and follow the directions. You'll need either a cheap hub, switch, or a simple crossover ethernet cable. Hook the thin client to one end, your PC to the other, run the tftpd32 program as described in the documentation, set up the thin client per documentation.
If all is done right, your thin client will grab an ip address from the tftpd32 program and you'll see the reflash menu. Pick the number corresponding to the proper reflash, and watch the machines do the rest.
When it's done, you'll have a pristine OS on your device.
now understand, these are made primarily for accessing terminal servers in businesses or schools or hospitals, so it may be useless unless you just want to do some primative web surfing (the CE version has an embedded version of IE5, no java, no flash, and probably no room to put it on that 16meg flash disk.)
But if you buy these devices for a accessing terminal servers, this will give you a clean client.
Jan 21, 2008 | Neoware Systems c50 Thin Client Network...
Upgrade 238622-001, Compaq Evo T30 Thin Client 300Mhz 32MB Flash/64MB/Win CE NET/IE 5.5 w/o
You need to replace the 2mbit bios chip used by the WinCE Evo with the 4mbit one used by the NTe and XPe Evo, then you need an add on flash module, since the onboard flash is too small. After that, just find the OS file and flash away. You can find the OS files and a utility to flash from the HP support site. You'll need a crossover ethernet cable, not a patch cable, to do the flash.
Jun 25, 2007 | Compaq EVO T30 Network Terminal
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Software on the MobilePro system to connect to a Windows Terminal Server
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
Compaq EVO T30 Network Terminal Logo
846 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
