Question about Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC
No sound no speaker icon
No sound and all the options in device manager is greyed out also says no sound device
  • Coss May 11, 2010
    More information about your computer please.
    Did it work before and stopped? Is this a new computer? Or an older computer that was reloaded or upgraded?
    Is the sound card a seperate device, or is it part of the motherboard?
    In device manager, does it show a sound card? Or does it say unknown device? Or have no devices listed?
  • 407 Answers
Hi when u open your pc if sound is show or xp sound run ......hope
your speaker jack check... ..
you go my computer properties then go hardware device
you can see any yellow mark.....if show any mark ? yellow your driver is not install ...then you install your motherboard driver .
Posted on Aug 30, 2008
How toinstal sound driver from internet?
Use the right mouse button over the Windows icon if in Win 8 or go to the Control Panel with any version. Get to the Device Manager. Open it. Look for the separate options and locate Sound. Check for Update. If updated, then go to the Desktop screen, lower right Speaker Icon to see if the Sound function is working. Check the options as to what speakers are active. If no speakers show up, you need to set the option to activate the speakers you are using. If necessary, use the HELP Menu.
May 09, 2014 | Intel Motherboard
My pc is ibm mt-m 82121yu.device manager show its audio driver is updated but sound it doesnot sound
See your sound settings in control panel, make sure that a little speaker icon is not grey, or choose sound device from list (activated one - possibly you are still using sound from motherboard, and must swith to your sound card).
Also make sure that your device has no exclamation signs in device manager, which would mean a bad or invalid driver, go to device manager and update the driver for device if device is yellow.
Apr 22, 2014 | IBM Computers & Internet
Audio windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope it helps
Jul 20, 2012 | ASUS P5PE-VM Motherboard
My headset mybe erased all drivers and this device no working properly win 7 no reconize it and I can't listening music in this device can you help me please. Thank you.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel hardware and sound manage audio devices playaback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list windows7
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further changes to your sound setting by right clicking on the speaker icon in the taskbar(bottom of screen)
hope this helps
Jul 22, 2011 | Computers & Internet
Wont work with win 7 64 bit .....
hope this helps
Jul 21, 2011 | Behringer FCA202 - FireWire Audio...
I was deleting things in add remove hardware and now my logitech x 240 speakers have stopped working, i also had a yellow ? appear in device management but i have downloaded something that seems to have...
There are two possibilities here which may be causing your problem.
Either you have not gone back in and enabled sounds in the control panel or you need to reinstall the speakers in the hardware manger and set the options to use them. That is "if" you have not deleted your sound card drivers?
to enable sounds, go to control pane, and then sounds and double click on it. Check to see if there is a sound sceme chosen (i.e. windows default). If there is no sceme chosen and its greyed out, click on the arrow and choose windows default and save it. It will tell you that your previous sceme may be lost if not saved first and ignore that warning - just continue.
Click the test option next to the sceme chosen and see if you can hear it?
If not, then continue troubleshooting and move to the next possible problem which is reinstallation of your speakers through the hardware manager.
Go to the control panel and find install a device or hardware manager (depending on which version of windows you are using). click on it. Windows will try and find the device you wish to install, if it locates the speakers then great just follow the prompts until installed. Then make sure the sound it turned on as indicated above and your done!
If it does not auto find the speakers you want to install, change the options to locate the item you wish to install yourself. Scroll the manufacturers drivers that came with your version of windows and find Logitech and the type of speakers you have which you want to install.
then follow the prompts to install the speakers. You might want to go back into the sounds icon in your control panel and check the optional tabs to make sure the type of audio device you are using is also the chosen default in your pc. (i.e. headphones, desktop speakers, or surround sound system ect.)
Mar 20, 2011 | Logitech Computers & Internet
Speakers is not working properly
You can first check for a speaker icon in your system tray (right bottom part of the screen). If you can see it, that means the sound card is properly installed in your Device Manager. (Control Panel, Device Manager). Click on the speaker icon to check whether your speaker is muted or the volume is lowered, make the necessary adjustments. If it case you don't see any speaker icon, it's whether your sound card is defective or not properly configures in the Device Manage. Go to your device manager and reinstall driver.
Good luck.
TedMac
Sep 18, 2010 | Acer Computers & Internet
My dell computer will not recognize the logitech speakers. I think it is something to do with the usb plug in versus a normal "jack" type plug in. I am using Vista as my OS>
Ok firstly make sure that the the speakers are connected to the green port at the back of the system tower. connect the usb cable to the usb port.
check with a headphone if there is sound . If sound is present then connect the speakers as above and then click start control panel - sounds - on this screen see if the speaker icon has a green check mark beside it , if not then click on the speakers and click use default device option present at the bottom of the screen. This should fix it.
In cases where the screen is greyed out .
strt - rgt click on computer - manage - device manager - audio device - chcek if ter is a yellow ! or red X beside it al;so check if you see other devices on screen
You could reinstall the audio drivers from the dell website support.dell.com for a DELL desktop . Reinstalling audio drivers should fix it.
try using the speaker on other system .
Hope its informative :)
Mar 31, 2010 | Logitech X-120 Computer Speakers
My compaq presario 700 laptop isn't putting out sound. How do I re-activate the sound abilities?
Do you see the sound/speaker icon in the taskbar? Check it first if it is muted. If there is no sound/speaker icon in the taskbar, try to go to the Device Manager to check if there is a sound driver installed in your laptop.
Jun 28, 2009 | Compaq Audio card Sound Card
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
