Question about Amana 24 in. ADB1200AW Built-In Dishwasher
Amana ADB 1200AWW
The door will not latch as the latch is in the locked position but the door is open
  • Amana Master
  • 19,396 Answers
Try first unlocking the door latch with a small screwdriver, unplug power cord before working on the door lock.
If this does not work buy a replacement door lock, or get it replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
My car door does not close,door lock is jamb
Check the latch assembly where the door closes. If the latch claw is closed it won't latch. Make sure the door is unlocked. Insert a screwdriver into the middle of the claw (circular opening where the striker latches). Open the door handle from inside or outside and pull sideways on the latch it should pop open. If it doesn't then the lock mechanism is in the lock position. Remove door panel follow lock rod to the latch and manually try to move the lever to the unlock position. If all fails you probably will need a new latch assembly.
Jan 30, 2011 | 2000 Ford Taurus
I think I turned the oven onto the clean when trying to turn the oven off. The door locked after I opened the door and now the door will not close because the latch is in the lock position. How do I get it...
normally pressing the clear/off button for three to five seconds should clear this mode and unlock the latch. you can also try and unplug the unit and press the clear off button
Nov 13, 2010 | Amana ACF4215 Electric Kitchen Range
Oven sef clean latch locked but door is open and I cannot clos it. I inadvertantly urned it to self clean and openedthe door and the latch is locked in self clean position. How do I release the latch so I...
Ok. Open the door and find the oven light switch(es) (some models had two switches). Press the switch(es) in and see if the latch goes back to the home position. If not enlist a volunteer to turn on the self clean cycle while you are holding the switch(es) in. Just after the self clean starts have them hit cancel and wait until the lock comes back to it's "home" or unlocked position.
Good luck!!
Jun 16, 2010 | Kitchen Ranges
I have a 2006 Saturn Vue. The front passenger
there is a spring inside the door lock that makes it work this spring is most likely broken try spraying lubricant on the lock just in case its binding ,but it seems like you will have to replace the lock mechanism
Feb 07, 2010 | 2006 Saturn Vue
The locking mechanism on the rear passenger door isnt working.The door will close but the metal catch will not lock.How do i repair?
I have seen some times the latch assemblys get rusty or dirty and the inside or outside door handles are pulled and the latch assembly siezes in the open position not allowing the door to latch closed..but this may not be the case .. check to see also if the child lock switch position is not stuck in the halfway position, also check if the latch has not flipped to the close position before the door was closed thus jamming the striker latch..this can be fixed by pulling the catch out while opening the door handle..hope this helps good luck...
Nov 05, 2009 | 1995 Pontiac Sunfire
I have an Amana smooth top and tonight we cleaned the oven. I turned the over off, and unlocked the latch. The door would not open. I tried locking it again and unlocking it, now the handle is broken and...
yes alot of times when you use the clean the door will latch then not unlock....these have micro switches that lock and unlock the door.....this is gonna be either one of the switches or the door latch assembly itself.
Oct 03, 2009 | Amana AER5515QA Electric Kitchen Range
Door latch problem
how to align the door to center the latch
Aug 26, 2009 | Amana 24 in. ADB1200AW Built-In Dishwasher
The door is open, but the latch is in a locked position.
it sounds like the child lock as been turned on,check the handle part to see if it as a **** in it were you can turn it with a screwdriver just turn this upwards or sidewards to see if the door will lock or open ?.rgrds,paul
Jul 07, 2009 | Washing Machines
Amana 24 in. ADB1200AW Built-In Dishwasher Logo
314 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
