Question about Numark PT01 Turntable
Where to buy stylus
I have searched all over the internet and can't seem to find a reliable site from which to purchase a new stylus for my turntable, do you know of any?
  • 3 Answers
You can buy them from here
http://www.djstore.com/
Posted on Feb 10, 2009
Sorry to say but if you have a Numark PT-01 you cant change the stylus
Posted on Jan 08, 2009
Purchase replacement stylus
Look at the cartridge it fits into and enter the model number and make of that into Google and search for that. The stylus will also be found.
Jan 31, 2014 | Teac SL-A100 Turntable
Spirit of St. Louis Turntable Art No. 541.809 stylus
You need only find the cartridge model and then search the net for it. That should find the stylus for it. Or you can replace the cartridge with a different make as long as it will fit in the headshell of the arm.
Jan 14, 2013 | Audio Players & Recorders
The arm for the turntable is loose
The "needle" is a stylus and you can find a source by searching the internet
Oct 06, 2012 | Stanton STR8-30 Turntable
Need a new stylus for my turntable SONY PS-LX250H and cannot seemed to find a new one. where can I get a new one at.
Assuming it is the original ATN-3600 cartridge, a simple web search for "sony ps-lx250h replacement stylus" or "atn3600 stylus" locates some.
If the cartridge is something different you should search for that model's stylus, not one for the TT itself.
Sep 03, 2011 | Sony PS-LX250H Turntable
Stanton turntable: STR8-30 need to find out where i can buy replacement stylus please help
You look at the cartridge, determine its make/model number if visible and web search for that with 'replacement stylus'. There is no way we can tell what is installed on it.
Aug 07, 2011 | Stanton STR8-30 Turntable
My str8-30 is fitted with a 500B cartridge and I can't seem to find what type of replacement stylus to buy. There is nothing on the needle to indicate what type it is. Any help would be appreciated.
just replace the whole cartridge go online to a site called partsexpress.com and order a new cart. or they might have the repl. stylus that you need.. good luk.
Mar 09, 2010 | Stanton STR8-30 Turntable
PARTS AND SERVICE FOR A USB TURNTABLE
here you go...this stylus is for the teac turntable but will fit the usb turtable you have!
http://www.lptunes.com/Replacement-forTeac-402-M208-165-402M208165-stylus-p/teac402m165.htm
if this is not the needle, just search around that site, i'm sure you'll find it! good luck!
Feb 11, 2009 | Audio Players & Recorders
Stylus will not catch
'Skating' is usually due to very low stylus pressure, which can be adjusted using a counterweight.
Is this the picture of the turntable ?
http://www.vintagetechnics.stereomanuals.com/turntables/sldd33.htm
Isn't that a counterweight at the back-end of the arm ? Can't it be rotated ?
If the counter weight is fixed, check the pickup mounting. May be it needs to be adjusted a bit forward (to increasing the stylus pressure).
Aug 20, 2008 | Technics Audio Players & Recorders
Turntable rotating slowly or not at all
First and foremost, are you sure you installed the correct replacement belt, and installed it correctly? Just ruling out the obvious. Now, if you installed the belt correctly, then the only other thing that could cause this is a bad motor. Not an expensive part, but with labor, it might be cheaper to just buy a new one. Figure the part itself is about You will more than likely be able to remove the cartridge/stylus and use it on your new turntable, just make sure the tonearm is the same style as your existing turntable - P-MOUNT Tonearm. If you buy another belt drive, you might even be able to keep the belt you purchased as a back up - might fit! Here is some part info on your turntable: - Belt - Part #SJY90080-3 - $5.99 - Motor - MOTOR, 4 VDC, .2 WATTS - Part #SDMB5E - $19.99 Labor - 30min This is just to give you an idea of what it would cost to replace the motor. I put the belt part # on there, just so you could verify that you bought the correct part. Hope this helps some. - Justin
Aug 02, 2007 | Technics SL-BD22 Turntable
Numark PT01 Turntable Logo
211 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
