My portable hard drive wont stay on with out playing with the usb cable. Any suggestions on how to clear the hard drive before it goes?
  • djhtfu Aug 29, 2008
    ITS DEF NOT THE CABLE GOT TONS LAYING AROUND. THE USB SEEMS TO BE LOOSE.. I HAVE TO MOVE IT AROUD TO GET A SEC OF POWER
Thnx ill try
Posted on Sep 02, 2008
  • 37 Answers
Um, you may not need to clear the drive, have you tried a new USB cable? sounds like there is a short in the one you have.
Posted on Aug 29, 2008
  • Micheal Martin
    Micheal Martin Aug 29, 2008
    if it the port, you can try taping the cable @ a angle that keeps power to the drive long enough to get your data off the drive, at which point most exteral drives are either IDE or SATA and you can remove them from the casing and put the drive into your PC, and transfer the data if the cable cannot be secured enough.
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
MY HARD DRIVE WONT LET ME WATCH DOWNLOADED MOVIES ON MY PS3
Could be the video format, make sure the video format is play-able on the PS3 and make sure the hard disk is formatted to a FAT32 file system.
Oct 29, 2012 | Seagate Expansion Portable 1TB USB 3.0...
I connect the USB 3.0 portable hard drive for Iomega its not working in my computer but i connect another computer its working tell me solution
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
May 23, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm SimpleTech SimpleDrive Portable USB 2.0 60GB wont show up
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Apr 22, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
Iomega eGo 1TB USB 3.0 Portable portable harddisk 500GB. while connected to PC show an error on desktop "insufficient power on USB hub port" . pls suggest
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer? 2. Try switching out your USB 3.0 cable for a different one. 3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable. Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's into the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer as they will supply more power than the USB's on the front of the computer.
Dec 20, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I just got an Imation Apollo UX 320 Gb without need of power supply from my brother in law, as a gift. The problem is that he gave it to me without the cable so I connected it to my computer with a cable I...
try a shorter usb cable long ones typically dont flow enough power unplug all other usb cables and make sure your computer is up to date with all Microsoft fixes [if your using windows] it should either auto-play and pop up or be viewable from [my computer] i hope this works please vote
Nov 29, 2010 | Imation 27390 Apollo Expert UX 2.5" 320GB...
Usb 2.0 portable drive has (5pin mini) will only work with usb cable that came with canon camera. other brand new usb 2.0 cable won't work. Tried this with 2 different drives and also with mac and PC
Suggestions:
(best to worst)
1. Use a "Y" USB cable with that drive.
2. Use a shorter USB cable.
3. Use the new cables with the canon
4. Use a 2.0 hub
The drive should have come with a "split" USB cable (USB "Y" cable). The drive requires a "data" and a "power" connection to your computer.
Get one at Radio Shack, Best Buy, Office Depot/Max... ($10)... or Dollar store ($1.09)
Oct 02, 2009 | Toshiba 200GB USB 2.0 Portable External...
How to get my hard drive to work.
external USB Drives, sometimes lack Power to perform properly.
you can purchase a lead that splits into 2 USB cables, using the dual cable, into 2 USB ports, can sometimes remedy This.
Mike @ compurepair.
Jan 11, 2008 | Toshiba 120GB USB 2.0 Portable External...
Maxtor OneTouch III 160GB Mini
Does the Maxtor have a 120 cord? If so how about using a converter? They are about 20-30 dollars and connect to the 12 v system of the car and can be placed anywhere.
Dec 28, 2007 | Maxtor 160GB OneTouch III Mini USB 2.0...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
