Question about Toshiba e570
E570 with GPS and Navi
I'm about to upgrade my e570 with GPS-Hardware and Navi-Software. Is there anybody with some experience in doing so?
    Master:
  • 903 Answers
Hi, I purchased a CF GPS card via ebay and TOM TOM software from a high street retailer and installed it. I now have a fine running e570 GPS and navigation system. Of course the maps needs to go onto a SD memory chip because of it's size. The GPS device was from DConnex.
Posted on Sep 11, 2005
    Master:
  • 903 Answers
Personally I have not GPS on my PDA but there is no reason that it should not work properly. The only thing is that you should pay attention on several things. Check by software producer if the software is compatible to your PDA. Please also be careful which ports use GPS hardware because your PDA has no USB port just serial port. With another words check all this important things before you buy anything.
How to upgraid my device?
If you're refering to upgrading your Navigation software, QuickGPSfix data and/or your current (out-dated) map, you can do it by connecting to the TomTom website (www.TomTom.com) using the TomTom HOME or MyDrive Connect software, depending on the model/version of your GPS device.
If you're refering to upgrading your GPS hardware/equipment, to have more capability/features, the device is not hardware upgradable, except for adding/using an SD card with a higher storage/memory capacity (to store more info/maps, etc.) ... provided you have a GPS device with an SD card slot.
You'll want to consider buying a newer model with more capabilities / features than what you have now.
May 21, 2016 | Tomtom XXL GPS
I need to update my nextar X3-11 gps and dont know how????
Unfortunately Nextar does not offer an update for your unit. See units with available updates below.
Map Upgrades for GPS:
The below units are upgradable with the Navi Extra maps.
  • Q4: From Serial #ML0909020001 onwards. From Serial #YF0909123953 onwards
  • Q4-06: From Serial # ML0909000001 onwards
  • ME: All serial numbers
  • 43LT: All serial numbers
  • V4: All serial numbers
  • V5: All serial numbers
  • I4-BC: From Serial# ML1004000001-ML1004000504 and ML1005001701-ML1005002700
Important Map Upgrade Information:
Please note that refurbished units that have serial numbers starting with MLR or ML999 are not compatible with map upgrades.
Navi Extra Mapping
Please note that Nextar is unable to answer map support questions once the Navi Extra mapping has been purchased. For any map related questions and/or refunds, please feel free to contact Navi Extra at:https://nextar.naviextras.com/shop/portal/support?selectedTab=contactus.
May 02, 2011 | Nextar X3 GPS Receiver
Application Navi.exe has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor. Program: Navi.exe Exception: 0xC0000005 Address: FFFFCBC0
You have a few corrupted files internally. Contact Rand Support to
obtain a new update SD Card to upgrade you to the new version and maps. The update SD Card will not remove your user
data. Be sure to have your serial number handy,
(back side, bottom right).
Oct 12, 2010 | Rand Mcnally TND 500 Car GPS Receiver
Have Smart NAVI DOTN300 put new battery in .does not load up.
this is a broblem with the softwear it dose not shut the gps off and run the thin dead you can upgrade the softwear to igo 8.34
Dec 12, 2009 | HandHeld Entertainment AvMap GeoSat2...
Fatal application error, program;mnavdce.exe,address;000A8444 unit will not activate navi
hard reset the device, turn it off on reset button/ power on/off...then wait for a minute before you switch it on...bingo! or else reinstall the software of your device..or else hardware issue (but this is more software issue).
Apr 17, 2009 | GPS
Dvd Gps Navi not exist
This took me weeks to solve because they dont give you a decent manual. It is necessary to have a good map on your sd card. You have to go into your map setup software and tell it which serial port and baud rate to use. otherwise it will display as you state.
Jan 21, 2009 | GPS
Web Site to Update GPS
http://www.navman.com/Navman/Templates/standardcontent____24709.aspx
I'm in Australia, so if you're not you will need to go to the navman website and select your country, then find the update. The update is done through the NavDesk software I think.
Jun 11, 2008 | Sony nav-u NV-U70 GPS Receiver
I need to download the updated map data to a Nav U 70
First, You MUST use the AC power adapter when connecting the unit to the computer. But if you are using the AC power and the message still is the same, try the following:
Note:Because each of these steps is a possible solution to the issue, check the status of the device after completeing each step.
!. Restart the computer
2. Close all applications that may be running
3. Temporarily disable any antivirus software you may be running
4. Reset the Nav-U unit by placing a safty pin or something likewise into the reset channel and hold down for approx. 15 sec.
5. Uninstall Microsoft ActiveSync from the Add/ Remove programs and then reinstall it using the Nav-U DVD
6. If possible, test it on another computer.
The troubleshooting steps listed above should resolve your isue. if not, service may be required.The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony authorized dealer.
May 22, 2008 | Sony nav-u NV-U70 GPS Receiver
Maps
By MS Active sync from computer delete file Mounted Volume/my flash/sony/nav-u.exe (the folder SONY is hidden, you must set show hidden files in your comuter first). And then replace old navi file by exe file of total commander CE version ( download is free on site of developer) .You must rename the totalcmd.exe to nav-u.exe. Now after reboot is allowed everything, including executing any other navi software like tomtom, igo, navigon and many other (multimedia players). The oficial navi (old navigon) by sony is not so good in compare with new navi soft. .. enjoy.
Dec 28, 2007 | Sony nav-u NV-U70 GPS Receiver
Media Player issue
Weird! I would try an alternative Windows CE MP3 player such as Xaudio or PalmPlayer to see if they do the same thing. I have trouble believing it's hardware related because AFAIK the MP3 decoding is all done in software, but I guess it's possible.
Sep 12, 2005 | HP Jornada 568 Pocket PC
Toshiba e570 Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
