Question about HP iPAQ H6340 Pocket PC
USB charging I've recently purchased a Ipaqh6340 ( 30/06/05). It appears that the USB charging feature no longer works! Originally I could charge my device in the cradle whilst using my PC, but I have noticed it won't charge anymore, and I have to use the mains lead coupled to the cradle. The USB charing option has been set, and I have tried both the slow & fast options with no sucess. Active sync seems to be unaffected. Any help/advise or a solution would be appreciated Thank you in advance.
  • HP Master
  • 3,427 Answers
A new battery.
try one.
12 year old batteries, be like hopeless. no?
why use this device, get a used android? x10 better, no?
Posted on May 27, 2017
3 Suggested Answers
adib
  • 450 Answers
SOURCE: AC charging issue
Sounds like a defective AC adapter.
Posted on Sep 11, 2005
  • 5 Answers
SOURCE: HP Ipaq h5550 does not connect through cradle
First sorry for my bad english.I have a same PDA (acually its dead :-( ) And me too had this problem.Try moving a little bit your pda on cardle, or (this looks like crazy but actually worked for me) do not fully put in the cardle into pda.I mean dont stick in into cardle, just a little bit.
Posted on Jul 03, 2008
Does the arcitec 1050cc come with a seperate charging stand as well as the jet clean device?
Originally, all Arcitec models came with a simple charging stand. That part is no longer available. If you need a simple charging method for your shaver, there is a charging/travel pod. It can be purchased at shaveroutlet.com at the link below
http://shaveroutlet.com/philips-norelco-arcitec-power-pod.html
Feb 12, 2015 | Philips Norelco arcitec 1050CC Electric...
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
I have just purchased a UNIDEN GPS iGO500. I've registered the device and tried to download Naviextras Toolbox but when trying to extract my laptop is saying that there is a virus in the program. I...
I got mine connected finally, the problem is you have to put the GPS in USB device mode not just charge mode, however the screen with this option on it fails to appear when you turn it on. I got a breif flash of it as I was turning it on and off and the USB mode button is to the right of center. Have to device plugged into the computer and turn it on when the loading screen appears keep pressing your finger to the right hand side and you will trigger the USB mode.
Sep 14, 2011 | Uniden GPS
Is there a special charging gadget to charge my onix mp3 player purchased from Aldi on 27jan2011- it did not come with the purchase of the player, only a usb cord that plugs into the player????
same as u, i bought one recently from Aldi... luckily i have proper usb cable can use borrow from other devices (i.e. card reader and external hard disk drive). i guess this cable tech. name is "USB A Male to USB Mini 5 B Male Cable". You can buy one from BigW, Kmart, Office Work etc. Of couse the cost will be cheaper if buy one from any local discount variety stores such as Reject, Go Lo, Hot Dollar etc. Oh, one more thing, there is no special charging gadget to charge the player. Just connect it to your PC with proper usb cable. It will charge by itself ~little
Jan 27, 2011 | Audio Players & Recorders
StreetPilot C330 (010-00401-10) GPS Receiver: I just recently purchased a Garmin GPS system for ...
If there are no power points in your vehicle, you might have to purchase a battery-operated powerpack and plug the GPS into that via a USB/AC adapter.
May 18, 2010 | Garmin StreetPilot C330 GPS Receiver
USB device does not work
Purchase a usb power plug to plug your device into the wall if it charges then your computer just needs to re install the device driver
Aug 29, 2009 | Sony NWZ-A816 Digital Media Player
Not recognised under USB
if you are having technical problem with your archos 605 just do this connect your USB with your computer and your archos device will pop up on the screen asking you if you want to charge your device or enaable usb that will automatically appear if your computer doesen't reconise the device then switch it off and on again if doesen't work then i suggest you look it up on the archos manual which is located on your device. if that doent work then i think you may need to update your computer it must have windows Core dual processor if that don't work and your archos device doesent appear then i think you may need to update your computer with a service pack 2 installation cd
Oct 01, 2008 | Archos 605 WiFi Digital Media Player
Trouble with my blacberry 8100
i have less than a month with my blackberry pearl and with no reason it just stopped working!!!i swear nothing happened to it, it just all of a sudden didnt turn on!!and yess....it wasb fully charged..any one with an answer why???
Aug 21, 2008 | RIM BlackBerry Pearl 8100
HP iPAQ H6340 Pocket PC Logo
118 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
