Question about GE Dryers
Very loud noise when dryer is turned on, very loud! tub bushing in back and the wear strips in fron of tub has been replaced. Would appreciate any HELP
  • 550 Answers
Usually there are two rubber wheels under the drum as well as the felt s and any nylon guides.
the wheels have bronze bush bearings, when the go they are noisy
~$9/pair.
easier to replace than the tub felts were
Posted on Aug 29, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Squeaking loud...when u turn it on
ck rollers in back of tub,this will require that you removethe tub.also ck the belt addjuster these need to be lubercated ever few years. ck also around the tub seals, sometimes coins left in chlothes will stick in or around & rub metal making noise.i would remove the belt from motor before trying anything.turn on air fluff setting. start dryer to see if noise is comeing from motor or tub.
Feb 25, 2013 | Maytag Dryers
Bosch WTMC3500UC Gas Dryer Dryer...as it is turning makes LOUD clanging banging noise. Will make the noise when turned by hand does not make the noise when tuned by hand in the other direction.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gkjlgkj
Feb 15, 2010 | Bosch WTMC3500UC Gas Dryer
Annoying road noise and binding noise when turning! Please Help!
ry checking the condition of your wheel bearings they may need servicing or replacing and cv joints
Oct 28, 2009 | 2004 Mitsubishi Endeavor
My 2006 Cobalt has a loud grinding sound coming from the drivers side front tire the noise only happens as I push the gas pedal, soon as I let off the noise has stopped. Thought at first to be the cv joint...
sounds like a wheel bearing noise. if you turn left hard does the noise go away or get better? if you do the opposite is it worse?
when jacked up does the wheel have up and down play.
Jun 25, 2009 | 2006 Chevrolet Cobalt
The dryer makes a loud noise and also a rubber smell develops after a 1/2 hour of use
My dryer did the same thing. I had to replace the front support glide assembly and needed 4 teflon glides.
The front part of the dryer runs over this plastic piece seen here upside down.
this part is about $50 CAN there are 4 plastic or teflon glides that fit into this.
My dryer had worn through the teflon glides and start wearing away this piece.
My dryer is a GE front load dryer. And I did get a burning smell because the dryer was wearing away the plastic. After the teflon strips wore down.
Hope this helps
Jun 01, 2009 | Kenmore Dryers
Loud noise
could be that one of the bearings that the tub rolls on is wearing out and needs to be replaced or the belt pulley running to the motor is worn and needs to be replaced. Hope this helps
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
I have a fridgeair front load stackable dryer. The dryer tub has problems getting started rotating. At times it also makes loud noises coming from the back center of tub. In order to get tub started...
Frigidaire Dryers use a ball and socket in the rear to support the drum. The socket is made of a Teflon type of plastic that will wear out when the grease is no longer present. By now, the ball of the drum is probably grinding away at the metal support for the socket, thus the loud noise. At the same time the front seals are probably worn out. These two things combined is causing alot of friction keeping the drum from turning freely. The parts required to fix these issues are not that expensive. Getting the dryer apart to replace these items however is time consuming and easier with two people.
The top panel, control panel, front panel and the drum will all have to be removed.
Jun 08, 2008 | Frigidaire Dryers
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
G E dryer
Open the service panel and look for a broken belt and does the motor spins. Let me know if you will need for further assistance. Good luck!
Sep 08, 2007 | Dryers
Dryers Logo
96 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
