Question about Panasonic KX-TG4500 Phone
Greetings Our custom greetings are not playing, the system has started using the factroy greetings on auto attendent. thank you Fred Lake Trinidad CO
  • fredlake Aug 29, 2008
    thank you
    Master:
  • 521 Answers
Ur phone must be reset to factory defaults by mistake.
Posted on Aug 29, 2008
  • tech expert12 Aug 29, 2008
    try to set ur phone for the greetings u want again if u r not able to set them then reset ur phone first by removing the battery and reinserting it after 5 mins and then make the settings accordingly as u wish to.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
I have a Panasonic KX-T7433 and want to change the Auto Attendant message. How do I do this?
An auto attendant in a Panasonic brand voice mail system (TVS/TVA/TVM etc.) is controlled from the message manager's phone. It is accessed by calling 165 and dialing #6 *998
Unfortunately, your question has no hard answer. Each voice mail and auto attendant is different. For example, in TVS boxes, we use custom greetings and store day messages in 30 and night in 60. There are 100 "custom" greeting slots and 32 "company" slots in a TVS box. In the newer TVA systems, the interface is visual and custom messages get assigned sequentially. In those systems, we start with 1 day and 2 night.
So, the best answer is to find the installation instructions. If you can't, then you can step through each custom greeting for the existing one, or log into the VM system and read the database.
Carl
Feb 16, 2011 | Panasonic KX-T7453 Corded Phone
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
How do I access the automated attendant menu on my Avaya 18 phone system?! thanks
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,3 for greetings, 1 for auto attendant number, 1 for day greeting 2 for night( if your using a night key at the receptionist station then it usus the night greeting) # to go past selector code, 1 to start recording 3 to accept greeting hang up when done
Apr 06, 2010 | Lucent PARTNER18 Corded Phone
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
I can not change the Auto Attendant Message on the phone . It wont let me change the auto-attandant message i put in the password as 1020000 and it says invalid! how can i get around it...no one knows the...
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Sep 15, 2009 | NorStar M7310 Corded Phone
Change new greeting removed old greeting
Sounds like you might be changing the wrong greeting. If your using a night button to toggle the auto attendant on and off the auto attendant is using the night greeting.
Aug 28, 2009 | Lucent PARTNER18 Corded Phone
Greeting message
Since you asked this question in a 76xx forum, you have a TDA phone system. A TDA has timers that set where unanswered phone calls route to, one of the ports being voice mail/auto attendant.
There is no "simple" explanation for setting auto attendant. Each installation is different. You first of all, have to know which phone system and voice mail you have, then, know how the AA was set up.
For example, in a TVA voice mail, the setup is visual. you log in via the console and drag icons to the screen that maps the call routing. Since you start with custom menu 1, it sets your custom greetings 1,2,3, etc. In a TVS, you build custom service menus by hand.
While phone intercept is straightforward, trunk (line) is not. The voice mail knows whether the call is coming from a phone or a trunk and each has to be defined. In the case of an extension, you already know it goes to a voice mailbox and plays the greetings established for that person. In the case of a trunk, it may be a different greeting for each trunk for day, night, lunch, and break. Those parameters are all set in the TDA and TVx both.
I hope your head hasn't spun around several times, but the best idea is to sit with your voice mail administrator and phone system installer and get the picture of how the system was designed. You should get specific instructions of how the system handles calls and how you change greetings. You need to get the passwords and instructions for mailboxes 998 (message manager) and 999 (system manager) and a location of all greetings.
If you're into learning, a copy of the manuals for the voice mail and the windows software (if TVA) should have been delivered to your site with the system. In addition, the PT Programming manual (PTPM) can be requested from your dealer and it will allow you to make changes to your TDA.
Spending 5-10 hours with the manual some time will give you a better idea how the systems work.
Also, a spare PC with USB ports and a network card could get you remote maintenance from your dealer and maybe get you free or reduced cost maintenance and changes.
I know this is probably not the answer you're looking for, but I hope it helps.
Carl
Oct 02, 2008 | Panasonic KX-T7630 Corded Phone
Problems with automated attendant on Axxess Inter-Tel Phone
When people call in they more than likely hit a Call Routing Application eventually. You would have to assign the greeting to the Day and/or Night greeting in order for it to play.
May 13, 2008 | Inter-Tel Axxess Corded Phone
Panasonic KX-TG4500 Phone Logo
217 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
