HP PSC 750 All-In-One InkJet Printer Logo
Posted on Aug 29, 2008
Replacing Print Cartridge
How do I change print cartridge on an hp psc 750 printer?
A
Anonymous
Where the gray and blue areas of the printer meet there is a place you can lift up to reach the ink cartridges. The left side is for the color, which is larger and the right side is for the black. There is a lever on top of each. Lift up and then pull the cartridge out. Remove the protective strip on the new cartridge and place in the same way you just removed the old cartridge. Once in, push down on the lever on top. Close the computer. Follow any other instructions indicated on the readout on printer (i.e. alligning).
Don't be afraid of pulling up (at a slight angle) on the cartridges as you remove them, they do fit snuggly. The levers on top fit firmly to make sure the cartridges are seated properly. They won't go down if the cartridge is not in place.
1helpful
How to change ink cartridge hp psc 750
1- Open the printer
2- Remove the ink cartridges from the print head.
3- Use cotton swabs dipped in hot water to thoroughly clean the print head.
4- Repeat this until there is no ink residue coming off on the cotton swab.
5- Once finished, allow to dry and replace the cartridges
1helpful
Installed black ink but hp psc 750 keeps saying install colour and i only have black ink. Can you operate this printer without colour in.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
1helpful
How can i print in just black with no color cartrage
in your printer you can use single cartridge but there should be both cartridge inserted in the printer.it will not print if only one cartridge inserted.so let the colour cartridge empty but it should be there in the printer.other wise it will not print.at present the problem in your printer is colour cartridge circuit is got faulty so the printer is not detecting the co,lour cartridge in it.so it ask for replacement.in this case you will have to compulsary get the replacement cartridge.you can buy new cartridge or recycles cartridge that will be quite cheaper then new cartridge.
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Color cartridge wont print
The color cartridge is defective. Sometimes, when the printer detects a refilled cartridge, it "marks" the cartridge as defective hence the refilled cartridge will not work on any printer.
HP PSC 750 PROBLEM
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
3answers
HP PSC 750 problem with printing
hi, does it print test page?? let me know
Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
k24674
Grand Canyon Tech
Grand Canyon Tech
