Question about Asrock P4VM800 Motherboard
No startup of the mother board
We n a set the power on the fan go on and than you can here some beep sound it not turn on it go after a few secon you can here the soun Beep Beep Beep and stop and than go again beep
  • bernadette capoquian Oct 28, 2008
    3 days ago there was a sudden electric power shut down when i was in the middle of surfing the net then went on again after an hour. when i turned on my pc there was a repeated booting so i reseated my memory card and then afterwards it doesn't boot anymore instead i hear repeated beeps after every 2 seconds. pls assist...my motherboard is foxconn core series K8M890M2MA
Sounds like a videocard problem. REseat your videocard and memory sticks making sure they are all well setaed...
Posted on Sep 26, 2008
Why dose my pc keep beeping andCan some one help me fix my pc to boot and video to work ?
Check out this site to determine what the beep code is saying.
http://www.computerhope.com/beep.htm
Remove and re-seat your RAM sticks. Try to get to BIOS and load default settings are just a few things to try.
Jun 10, 2014 | Systemax Ascent PC Desktop
Continuous beep motherboard will not boot
check the battery for the mother board memory. flat battery can make it no startup. also if that is fine remover the hard drive lead and turn on if it comes on then the hard drive is causing the fault. do same with rom's.
Mar 24, 2014 | HP ECS ACER 946GZT-AM V1.0 SOCKET- LGA775...
Gateway Desktop GM5626: Would not power-up, replaced Power Supply; Then Mother Board beep once when trying to turn-on; replaced Mother Board; Mother Board lights on, but when I try to turn on the CPU...
some powersuplay comes with 2 extra connectors a 4pin based switch connector and a alternate power supply for the fan...you must to be sure if it is comatible......check the model and search on google for compatibility ...
May 31, 2011 | Computers & Internet
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
My compaq laptop F500 has black screen when power on
That sounds like a power supply problem. That would be the first thing I would check. If it was the processor, you would have heard a long beeping sound or if it was the memory you would hear about three 'annoying beeps'. The main reason you indicated there is no display on the screen and that the fan spins for a few seconds then shuts off, would hint that power is not going to the mother board long enough to spin the processor or cooling fan. Hope this helps :)
Apr 17, 2010 | Compaq Presario 700 470024-192 Notebook
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
My intel D845GVSR mother board can not boot .. nd no display.. it just starts for few secons then stops
Check your memory sticks.one could be bad or not seated correctly.
Take the memory sticks out and put back in,also check for dust ir dirt on fans and processor area.
Jan 20, 2010 | Intel Computers & Internet
No video from motehr board, no beep on power up?
No video and no beep on power up. Your video card is failure and internal speaker is lost, so You can't hear beep sound. or may be motherboard problem. You insert a external Video Card in PCI slot, if video is ok, so your video chip is damaged.
Thanks
Aug 16, 2009 | Intel D915GEV Motherboard
No display in a board
hello
the beep is due to ram
try to remove ram and insert again while power is off
Nov 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
Asrock P4VM800 Motherboard Logo
233 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
