Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Constant green blinking light Mitsubishi tv WS-65513
The green led light constantly blinks. I tried the reset button and green light is still blinking. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
senioM seD
Yes I am having the sme problem as the other people are and the green light just keeps flashing and has been for almost 2 days now. It used to do it occasionally and then one time it took over and hour to go out but now it won't. I have unplugged the tv and hit the reset numerous times to no avail. Please let me know what I need to do to fix this. Thanks for your help with this.
Tom
tlemore@aol.com
  • Mitsubishi Master
  • 8,617 Answers
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Posted on Aug 31, 2008
2 Suggested Answers
SOURCE: constant green blinking light Mitsubishi tv WS-65513
Hello all. I have fixed my green blinking light problem on my Mit. 65513 rear project. hdtv. It is on now as I'm writing. I replaced 4 capacitors on the DM board (largest vertical standing board). I used a desolder tool from RS($15).I practiced on a discarded board first. I replaced the caps with 4 radial capacitors rated 1000uf 16v. 105 degrees c and was sure to match the polarity markings on the board(+/-)with the markings on the capacitors. That's it! I also installed a small 12v PC fan(wired to a 12v wall adapter) on the DM module casing with zip ties. You may also use 1000uf 25v 105c caps. I hope this helps-good luck!
Posted on Jan 30, 2008
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinkink light
Good Day, jcarnell;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 05, 2008 | Mitsubishi WS-65513 65" Rear Projection...
First wait 90 sec. after power is applied before turning on. If still blinking forever "this is a common problem with the mitsubishi V23 chassis, There are four 1000 UF capacitors in the DM module that go bad. Location #'s c9b01,c9b02,c9b10 and c9b11. The DM module is the large steel card cage on the left side when looking inside with the back off. Once you get the cage out, remove the board. The caps are the larger ones on the top of the board. They will more then likely be bulged out on top or exploded. Replace with 1000 UF @16V or better. This should get you going again. I've done about 15 of these repairs in the last year. Note: try not to mangle the copper grounding fingers. Good Luck.
Jan 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65513
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
Jul 14, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
