Question about Toshiba e400 Pocket PC
Problem serial connection e400 using cradle
Using a Win NT machine I need a serial connection to synchronise the pda with outlook. So I bought the cradle with usb and serial (same as for e800)connectors. However I can NOT get any serial connection with the NT or other XP computers. It seems to me that the e400 can not recognise the serial protocol. Even after a hard reset the connection can not be made. So 2 questions: 1) Does anyone have had a serial connection (on mobile2003)? 2) Can anyone give tips how to create connection?
    Master:
  • 903 Answers
I am not 100% sure if I am correct in this, but I am quite sure that the e400 does not support a serial connection. Only the e800 does.
Posted on Sep 11, 2005
No connection beetwen my Sony ercsson p900 and my computer by usb
hello there!!! thanks for using Fixya.com!
just a little information...
PDA USB Sync/Charger/Data Cable for Sony-Ericsson P800,Sony-Ericsson P900 Features:
  • USB Sync/Charge Data Cable for Sony-Ericsson P800,Sony-Ericsson P900
  • Auto Sync with computer in USB port and charge Sony-Ericsson P800,Sony-Ericsson P900 PDA with same cable
  • Directly connects with USB port, need no extra power
  • Plug and play, need not software installation
  • Eliminates the need for cradle and AC/DC converter when traveling
  • Compact, lightweight and easy to use
  • One of the best USB hotsync data cable for Sony-Ericsson P800,Sony-Ericsson P900!
    If you experience problems when using the USB cable during synchronisation:
    1. Check that the USB cable is properly connected to the phone and the computer.
    2. Make sure the phone is turned on.
    3. Restart the computer, without disconnecting the USB cable or turning off the phone, and try to synchronise again.
    4. If you still experience problems using synchronisation software, e.g. Sony Ericsson PC Suite or Active Sync, try to uninstall and reinstall the program you are using.tang-shop_2031_105590869 Or you may go to this website for further information http://www.sonyericsson.com/cws/support/phones/detailed/usbcableissues/p900
  • Feb 09, 2009 | Sony Ericsson w580i Cellular Phone
    SYNC LGKU990 to PC
    This is what sorted it out for me.
    When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
    Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
    Let me know if that helped.
    Sep 04, 2008 | LG KU990 Viewty
    HP Ipaq h5550 does not connect through cradle
    First sorry for my bad english.I have a same PDA (acually its dead :-( ) And me too had this problem.Try moving a little bit your pda on cardle, or (this looks like crazy but actually worked for me) do not fully put in the cardle into pda.I mean dont stick in into cardle, just a little bit.
    Jun 30, 2008 | HP iPAQ H5550 Pocket PC
    Incomplete synchronisation of contact list
    If it is MS office software on the PDA the fields should convert. Problems arrive with different versions though. What is the Software you are using on the PDA? (and version, and version of win)?
    Jun 09, 2008 | Sharp Wizard OZ-290
    PC/PDA "connected" yet PC won't read PDA
    try syncing through bluetooth, there could be a problem with the cradle. i have had an issue very similar to yours and had to do a soft reset on my pda. then set up your device to use a blue tooth connection( you may need to buy a bluetooth dongle for your pc).
    Feb 06, 2008 | Compaq iPAQ H3850 Pocket PC
    Sync problem
    I assume you use activesync. Check in the options that it is set to synchronise this data. if you have already done this try reinstalling activesync or installing the newest version, 4.0.
    Sep 15, 2005 | Dell Axim X3 Pocket PC
    Sync problem
    I am assuming you use activesync. Check in the options that it is set to synchronise this data. If you have already done this try reinstalling activesync or installing the newest version, 4.0.
    Migrating software and data to new computer
    Assume that your Visor is your data respository. So you should make sure that you have an up-to-date synchronization from the NT PC. Now get the XP compatible software for your Visor from the palmOne website and install it on the XP box. I assume that you will be synching via USB this time - this is the default setup when you install the software. Hopefully you still have the USB cradle that came with the Visor. You can still use serial sync with XP but you should try to take advantage of the speed of USB on the new PC. Download for XP & Visors: http://www.palmone.com/us/support/downloads/visor/win_desktop_401.html Once the software is installed, sync with the new computer and all your data should be copied from the Visor to your PC in the first synchronization. By the way, Outlook shouild be installed on the new computer before you install the Visor software; otherwise the installer will not offfer to install the PocketMirror conduits.
    Sep 13, 2005 | Handspring Visor Deluxe Handheld
    Serial number
    Usually it should be on the back side of PDA
    Sep 11, 2005 | Toshiba e400 Pocket PC
    Microsoft Outlook data won't synch
    In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
    Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
    Toshiba e400 Pocket PC Logo
    121 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
