Question about Hitachi 53UDX10B 53" Rear Projection Television
NO POWER We have a Hitachi 53SBX59B. I went to turn it on and heard it power up but it never came on. No sound, no video. We called Hitachi who had us unplug and replug back in. The red power lite came on and immediatley went right off. The tech said without being able to power up couldn't make any reccomendations. Any suggestions and rough cost for that type repair Thanks for the help
  • 927 Answers
Good Day, david375;
There toooooo many things in the TV that could go wrong, so it's hard to determine what wrong. The avg cost is about $550.00 For some one to come to your home and repair it there.
good Luck, big IRISH.
Posted on Sep 01, 2008
No picture
OK, the set is on if get the menu display and you have sound--either a video circuit problem or a glitch.
Do you get picture via the rear audio and video input jacks? this will rule some things out.
Also if not tried disconnect set, any box used, or a receiver from power for several minutes and power back (possible glitch).
Dec 21, 2012 | Hitachi 53SBX59B 53" Rear Projection...
The picture just went off we heard a pop then no pic. We have sound . It is 6 years old appr.
It is the bulb, fuze, power board, or video processing board. Only the bulb or a fuze is user replaceable. All others you should seek out a qualified service tech.
Mar 20, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I HAVE A 1995 HITACHI 50UX19KV5F018305 THE TV WONT TURN ON
check for blown fuses, power regulators, in powr area, resoldering and general service is required...
Oct 30, 2009 | Hitachi 53SBX59B 53" Rear Projection...
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Digital Compatibility
TVs, VCRs, DVD players, camcorders and video games will continue to work, even if they are only analog-capable. Such equipment, however, may not provide digital-quality picture and sound.
Hope this helps.
Feb 16, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 50" big screen TV
You have a defective light engine and Hitachi is aware of it. Here's what you need to do...recently went through this. Call Hitachis customer relations department at 800-654-7013 and tell them you have a defective light engine. At first, they will act like they've not heard of this problem but they are all too familiar with it. They will give you the names of some certified dealers in your area. Once the tech comes out and confirms the problem, call Hitachi back at the 800 # I listed and they will call and confirm with the dealer that you have a bad light engine. They will send a brand new light engine to the dealer (Hitachi will cover the cost $1500) and the dealer will call you to come out and install.
Here's the kicker, if you're not still under warranty, Hitachi will cover the expensive part but you will have to pay the install. Our install was $400 but others on this site have paid around $200. If you're still under warranty, Hitachi will cover the part and install.
Please do not let any dealer tell you that you have to pay for this part. Hitachi has not recalled this part but they are replacing it to you for free...you just pay the install. Also, deal only with their customer relations at the 800# I listed.Good Luck:)
Feb 12, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 53SBX59b Rear projection TV out of convergence
from you bought the tv and notice that it has that stain on the edge you should have taken it back as it was covered under warranty.now it is getting worse it will cost you to get it fix your tv has a factory defect.you will have to call the repair man to fix your tv.good luck.
Apr 26, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
89 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
