Question about Garmin Data Card Programmer GPS Receiver
Connecting to USB Port
Please help.. I purchased a 260w and need to register the unit. I have no idea (I am so computer illiterate) how to connect the garmin unit into the usb port. I know, stupid, but need answer. thank you.
    Brigadier General:
  • 5,158 Answers
You'll need a usb cable... then go to www.garmin.com
the small end of the usb cable goes into the back of the gps... the larger end into the usb port... the computer should find it for you.
Robert
Please rate this solution .. thanks
Posted on Jan 24, 2009
I can not install the map on to my 260w garmin
connect the unit to the computer using a USB data cable and then go to www.garmin.com and register the unit, if your unit is new you get one free update with-in 90 days if outside that time frame you will have to purchase either a one time update for 49.99 or lifetime updates for 89.99
Sep 11, 2011 | Garmin nuvi 260W GPS Receiver
I have been trying to register my new nuvi 1410 which i bought on saturday . I get as far as " Please wait while communicator plugin detects your connected device " How long should this take ?
Please make sure that you are connecting the usb cable directly to a usb port on your computer and NOT through a usb hub. Then make sure you are registered with Garmin and have downloaded the latest Garmin updater software. Make sure that the unit is fully charged. Once it is connected and recognized the map update can take hours even with a fast internet connection.
Thanks for using FixYa.
Here is the link to Garmin to get started correctly:
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 23, 2011 | Garmin GPS
I have a seagate external drive of a capacity of 250GB. the free space available is 177 GB. the hard disk is very slow? please help?
Are you connecting this high-speed ("USB 2.0") device to a low-speed ("USB 1.1") USB-port on your computer? If so, and your computer has a "USB 2.0" port, connect your device to that port.
If not, then purchase an add-in PCI card for your computer, to add "USB 2.0" port(s).
Nov 10, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Updating maps
unit unit Off
plug unit into computer using the usb cable
go to www.MyGarmin.com register for free and update maps and firmware
Jun 26, 2010 | Garmin nuvi 260W GPS Receiver
Where is the usb port on the unit to plug into my computer? dont see one
You have to have a mini usb to usb connecter. the small port on the back, the charging port acts as the usb port. unfortunatly they don't come with one.
May 12, 2010 | Garmin nuvi 260W GPS Receiver
When connects to power in the car, it thinks it is connecting to the computer.
if your charger not original garmin you should make this modification on mini usb port. tested works with non original chargers (min 500mA).
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
System software missing
BEFORE you connect the Garmin to your computer you must download the free Garmin program on your computer called UPDATER. Did you do that?
If not:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater AFTER installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260w not operating while plugged in
If you are trying to use your unit in the car via the USB port and not the supplied cable, it will not work. You must use the bracket that came with the unit or the specific charger that came with the unit. The pins in the Garmin USB charger only use two pins whereas a regular charge cable uses 4.
Aug 14, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
85 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
