Question about Denon AVR-1803 Receiver
Denon AVR 1306
Hi (SORRY MY DENON AMP WASNT LISTED IN YOUR FILE?)
I've just bought a denon avr 1306 amp and speaker package. Im having trouble connecting the speaker wires to the back of the amp..im not sure how you do this. It has red and black knobs which unscrew..ive tried putting the wires in it and rescrewing them but there still oose..?? can you tell me what i need to do?
Thanks
Russ
  • 7 Answers
SOURCE: Denon AVF988 to power amp to whole house speakers
jbell302, Check both remote spkers for operation from the A spks output if good, switch B remote spks to A main connect & main A spks to the B remote connection on the Denon spks outputs . Most amp sources do not like different ohm spks types & different cable or spks A-B. lenghts, because this makes up to resistances problems, making the amp to work harder & understanding what is going on. THE AMPS PROTECTION CIRCUIT IS AT ALERT & TRIES TO BALANCE THE RESISTANCE VOLUME. Best move is to try use the same spks. lenght & a higher qauge wire; 12.14.18qa. to better balance the output volume! All matching spks. pairs would help alot as well!
Posted on Feb 04, 2009
tech48
  • 624 Answers
SOURCE: wiring speakers to denon avr 3802
Those are not compatible speakers for this unit. The Denon receiver does not have any speaker outputs for that type of speaker.
The Denon speaker outputs are full range outputs. Your speakers are not designed for that, they need an amplifier that has seperate outputs for the highs and lows.
By using these speakers you will probably damage them and they will not sound very good as well. The tweeters will end up fried and it is also likely that if one of the speakers goes bad, it will blow one of the channels in the amplifier.
If you really want to do it anyways, and don't say I didn't warn you, you could connect them using the "A" and "B" speaker outputs. Connect the woofers on one set, lets say "A", and the tweeters on the other, lets say "B". Right channel "A" would be the woofer and right channel "B" would be the tweeter for one speaker.
When listening to the unit you would need to engage both the "A" and "B" speaker to hear anything from both speakers, there are buttons on the display for the speakers marked "A" and "B" and in the display you would see little icons that light up when the speakers are engaged.
I can not stress it to you enough that this is not a good idea to use these speakers with this type of receiver. Do this at your own risk and be prepared to pay about $150 to $200 for the repair bill after the amp blows a channel.
Posted on Jun 22, 2008
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
  • 119 Answers
SOURCE: Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Posted on Mar 02, 2009
GodBlessU
  • 3513 Answers
SOURCE: denon avr-790 sirius antenna antenna connection
The connection is similar to what is mentioned in the user manual bellow. Slightly different model but the connections are universally similar:
http://www.rotel.com/content/manuals_archived/rb850.pdf
Thank You
Posted on Oct 31, 2010
How do I turn tape monitoring on my Denon AVR 3803 on/off? I recently purchased a set of Series V Bose 901's and I am having a difficult time figuring out how to activate the equalizer.
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Oh, but you don't have pre-outs. Bummer. Most AVR's will NOT pass digital sources to analog tape outs. Page 40 of the manual confirms that.
no can do. sorry. You need Pre-Outs to feed an external amp.
May 22, 2011 | Denon AVR-1803 Receiver
Feb 04, 2009 | Denon AVR-3805 Receiver
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
barneyluc
Oct 10, 2008 | Denon AVR 2808Ci Receiver
No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Sep 30, 2008 | Audio Players & Recorders
Wiring speakers to denon avr 3802
Mar 08, 2008 | Denon AVR-3802 Receiver
AVR-1603 - no Sound exept over Headphones is a weak signal
First check the outputs at the output fets/transistors for any DC voltage. Reference your voltmeter to the speaker - terminal. If there is ANY DC offset, the amp is shutting down the outputs to protect your speakers from DC. Is the power supply + and - 47 volts? If only one supply is there That is your problem because the supplies should be symmetrical. Also look for any wiring problems from the amp to your speakers... any shorts? Try disconnecting all your speakers to totally eliminate any speaker problem and see if the relays still click. You should hear only ONE click when you first turn the amp on (delay of about 2-5 seconds). If they keep clicking the amp outputs are next. Also, is there any indication on the front panel of what is failing?
Jul 29, 2007 | Denon AVR-1603 Receiver
Avr receiver
More than likely audio o/p problem.could be speaker problem,dissconnect speakers and try to power on if still no go it is job for technician.If it works one of your speakers has a short on it,good luck
May 14, 2007 | Denon AVR-1601 Receiver
Denon AVR-1803 Receiver Logo
241 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
