My washing machine wont spin - is it the carbon brushes on the motor - bendix biw 85
  • jimad1 Aug 29, 2008
    bendix washer wont spin
I replaced the carbon brushes on the motor and now its working
Posted on Aug 31, 2008
Why won't the drum spin on my washing machine and can I fix it myself
Very likely the brushes are worn, these are located either side of the motor. if you are able to take the motor off the machine but don't know where the brushes are, take the motor to your local repairer who will probably change the brushes for you at a small fee plus brushes. if you are able to identify the brushes and can take them off, the carbon inside the brush holder should be no less than half and inch long. If its less they are probably worn out. get new ones and replace. be careful the carbon brush is very brittle and will break easily. I can't be more specific on changing the brushes as each machine is different.
Oct 17, 2014 | Tricity Bendix Biw125w Washing Machine...
My washer wont spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor more Beko WME7247W test videos at site
Aug 08, 2014 | Beko WME7247W Washing Machine
Why wont it spin fast
Hi if your Beko washing machine has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Water control valve washer
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 11, 2014 | Beko WM5140W
My Bendix BIW103W washing machine has stopped spinning properly. The water drains correctly and the machine starts to spin, but stops after a couple of seconds with a click. I've read it could be the...
Timers can be expensive whereas brushes generally arent. First of all unplug the machine and tilt it over. You will see the plastic brush holders either side of the motor at the back. You need to prize them out carefully and check if they are protuding over the end. If they are they are probably ok. Then you need some fine sandpaper. Hold this through the brush holder gap and press against the coil inside. Turn the motor by hand thus cleaning it off. Then put it back together and try it again.
Oct 27, 2011 | Tricity Bendix AW1000W Front Load Washer
Beko washing machine wont go into full spin
Carbon brushes on motor need renewing. Not terribly difficult job. Be sure to disconnect from power before attempting.
Feb 28, 2010 | Washing Machines
My servis washing machine turns and empties but wont spin machine isnt spinning
I suggest you remove motor and check the carbon brushes fitted at the end of the motor, if they are less than 2-3mm long ,they need replacing.
Plz rate my solution
Thanks.
Jan 04, 2009 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
198 people viewed this question
Top Washing Machines Experts
