Question about Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher
My dishwasher isn't cleaning my dishes!!!
There is water coming in from somewhere, but it's not spraying the dishes - HELP ME!!! I have 4 kids and no dishwasher, I'm dying!!!
  • loveldyanne
    loveldyanne Nov 13, 2012
    Where is the filter?
Look and see if the seals at the back of the dishwasher are worn. They may need to be replaced. The seals are easily removed and new ones replaced. If that isnt it then check to make sure the pump screen is not clogged. Remove the screws to the covers in the bottom of the dishwasher to expose the screen.
Posted on Apr 13, 2009
Dishwasher not cleaning dishes
DISHWASHER NOT CLEANING WELL??
Here are 5 common reasons why not.
Here are Improper Water Temperature
I can tell you from personal experience that water temperature has a direct impact on how well your family's dishwasher operates. If the water entering your dishwasher is not hot enough, your dishes are likely to come out coated with grease and dish detergent residue. As such, you will want to make sure that the temperature of the water inside your dishwasher is somewhere between the range of 120 degrees Fahrenheit and 140 degrees Fahrenheit. If it's not it could be a faulty heating element.
Dirty Pump
Based on my experience, a dirty dishwasher pump will also cause your dishwasher to produce less than stellar results. Therefore, you may want to consider cleaning your dishwasher's pump every six months. In many instances, it is an easy task to complete. In order to clean your dishwasher's pump, you'll most likely have to remove the dishwasher's spray arms. Once the spray arms are removed, you'll want to clean and inspect the pump's impellers, blades and pump guard. I should also mention that there are appliance companies that sell dishwasher pump repair kits should you notice that a part needs to be replaced. A basic dishwasher pump repair kit will tend to cost you $20 to $60 depending on your dishwasher's unique needs.
Dirty Spray Arm
Dirty spray arms may also be to blame. After all, if the spray arms' holes are clogged, the hot water won't be able to reach the dishes properly. A dishwasher's spray arms are very simple to clean. In order to clean them, you will need an old toothbrush and a bread twist tie that has been stripped of its paper. Use the toothbrush's bristles and the wire from the bread twist tie to unclog all the holes.
Broken Dish Detergent Dispenser
A broken dish detergent dispenser is another likely culprit when it comes to dish cleanliness problems. Sometimes the dish detergent dispenser's door will not open or shut properly, which prevents the dishes from getting nice and soapy. The good news is that most dish detergent dispenser problems may be solved relatively inexpensively. The cost of a replacement dish detergent dispenser will vary based on the make and model of your dishwasher. There are also instructional videos online that will help you with the installation of your dishwasher's new detergent dispenser.
Dirty Filter
A filter has an impact on a dishwasher's effectiveness as well. Hence, you will want to inspect your dishwasher's filter for obstructions. The location and type of filter will vary based on your dishwasher's make and model. I would recommend that you check out your dishwasher's operator's manual. It should contain instructions on how to clean your particular unit's filter as well as where you can order a replacement part if need be.
Dec 16, 2013 | Dishwashers
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
My dishwasher is not cleaning the dishes on the top rack. there seems to be water dripping from the top inside of the dishwasher but the dishes are not being cleaned. I am making sure the funnel on the top...
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 03, 2011 | Frigidaire FDB949GF Dishwasher
Soap gets clotted is soap dispenser. Dishes greasy and dirty after cycle.
Hi, the soap is clotting because there isn't enough water being sprayed around inside. The water spray washes the soap out of the dish, if all is working well. My machine had the same problem. I had sufficient water level, but the spray head wasn't spinning very well. I found the end-most hole in the spray bar to be plugged. It is the end hole that provides a jet that makes the head spin. I cleaned a bunch of debris out of the hole and the machine started working and cleaning like it was new.
Jun 26, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
My dishes and glasses do not come out clean they appear to have some white residue on them...my water softner is working I am using liquid dish washer detergent and jet dry......just feel the washer is not...
If your dishes or glassware appear with a white residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Sep 03, 2010 | GE Dishwashers
Dishwasher not cleaning the dishes anymore, leaves a film on
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Apr 10, 2010 | Kenmore 24 in. 16299 Built-in Dishwasher
We have an Admiral Dishwasher that won't clean all the dishes properly. It leaves white film residue on some of the dishes and silverware. Have tried different products to clear this up with nothing...
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Please rate the solution if you feel I've helped you
Apr 04, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Filter/Drain Grate
  • filter
  • . Detergent or Detergent Cup
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Top Dishes not coming clean
    Clean ot replace circulation pump.
    Clean or replce hoses
    Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
    Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher Logo
    715 people viewed this question
    Top Maytag Dishwashers Experts
    Mike Cairns
    Mike Cairns
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
