Question about BenQ PE5120 Multimedia Projector
Replacing the lamp
I have replaced the lamp but the projector will not allow me to reset the lamp hours as per the manual.
  • 1 more comment
  • aceconte Jan 14, 2009
    I have the same problem. Did you ever get your issue resolved? If so, how?
  • elsie240 Jan 24, 2009
    same problem. Please post solution if there is one
  • eDD0 Feb 21, 2009
    I was told the same thing...i've just upgraded instead!
  • 3 Answers
We contacted BenQ's technical service people from the toll free number on their website. They had us do the same thing the manual said to do and of course the lamp hours would not reset. We had to send the projector to them and they responded that our mother board went and that it needs to be replaced. They've quoted us around $180. What happened to us was that we didn't change the bulb when the warnings came up on the screen. It isn't explained anywhere that if you wait til you get to 3000 hrs without changing the bulb that you could screw up your machine, but it's kind of looking that way. If I were you guys, I would make that call to their tech support and see what they tell you.
Posted on Feb 20, 2009
The lamp does not attempt to turn on anymore on my Runco VX-1C projector. Power to the projector is good but lamp does not turn on.
I was about to chime in that you should reset the lamp hours after inserting the new bulb ... until I read that you couldn't see the menu because the bulb still doesn't turn on. Hmmm...
Have you checked all of the filters to ensure they're free of dust build-up? I'm wondering if it overheated which caused the fault.
Due to the fact that this model is out-of-production your options have become limited. I recommend at this point you give them a call:
Tech Support at 800-23-RUNCO
Jan 02, 2015 | Runco Reflection VX-1c Multimedia...
Lamp didn't strike
lamps are affected by strikes. each strike erodes a part of the anode. so in essence, the lamp wears out. However a Xenon has a much longer hour life as once it is running, it cares "relatively" little about how long. SO for commercial units, this is an advantage. there are also larger potential issues about colour stability over life.
with UHP, they care only minimally about strikes, it really is not even a strike, so while frequent on and off can kill it early, with normal usage, you are going to be fine. However with a UHP, if a lamp runs for longer times... then you have issues. THe way i had it explained to me was as such;
With a UHP, it gets up to proper operating temp in about 5 mins. once it is there... it SLOOWWWLLLLLYYYYY continues to heat up. After about 2-3 hours, it starts going outside the nominal operating range. once it does so, it starts to degrade the lamp. thereby lowering life expectancy. if you shut it off after about two hours or so and let it cool for ten mins then do it again for two hours... you are in a much better place. In a grand scheme, apparently if you run the proj for an average of 4-6 hours every time, then expected lamp life goes to about 50%. THis is very rough and in a general sense so just take it as general guidelines.
Lamp life for a projector will vary based on many factors including application, installation, intake of cool air and exhaust of hot air, usage, and proper maintenance. Heat buildup can reduce lamp life and even damage your projector. Here are some tips to help your projector lamps last longer.
Once you turn on your projector, wait at least five minutes before turning it off to allow the fan to properly cool the unit. After the fan has cooled your projector, you may unplug it and store it as desired.
Do not obstruct the air intake or exhaust vent. Paper should not be placed on top of a projector, or where vents are located.
Keep the exhaust vent at least two feet from any object.
If the projector is built into a compartment, wall, ceiling or shelf mount, the minimum distance requirement (usually at least two feet) stated in your owners manual must be maintained.
Clean the projector's air intake filter every three to six months -- or more frequently -- based on your operating environment.
Do not move your projector until the lamp has cooled (about five minutes).
Run your projector for two weeks and/or 20 hours shortly after your purchase. If the lamp is going to fail, it will usually occur within the first ten hours of operation. Lamp warranties typically last just 90-180 days from the date of purchase, rather than the first installation.
When you purchase a replacement lamp for your projector, remove the existing lamp and use the old lamp as your spare. If your projector is new, test the original lamp for the two weeks/20 hours before removing and storing as a spare.
I hope the info. which i have given you solves ur problem if not i am sad to say you have to get it repaired..
Please don't forget to rate me as fixya..
Feb 11, 2008 | ASK Proxima C170 Multimedia Projector
Replace HP VP6321 Projector Lamp Models: HP VP6321 / HP VP6320 / HP VP6310 / HP...
Models: HP VP6321 / HP VP6320 / HP VP6310 / HP VP6300
Here are the steps to replace an HP VP6321 Projector Lamp:
  1. Turn off the projector and allow it to cool for 30 minutes.
  2. Unplug the power cord.
  3. Press the release latch (1) on the lamp cover and remove the cover (2).
  4. Press the release latch on the lamp connector and unplug the connector (3).
5. Loosen the two screws (4) on the lamp module, and pull out the module (5).
6. Insert the new lamp module into the projector and tighten the two screws.
7. Plug in the lamp connector.
8. Snap the lamp cover into place.
9. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp.
10. On the projector, press Enter.
11. Advanced setup, then Reset lamp hours.
12. Press Enter.
The lamp module has now been replaced and the projector is ready for use.
I hope that helps.
Download Hp VP6321 Manual here.
on Apr 23, 2010 | HP vp6320 Multimedia Projector
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
I just got a new bulb for my projector. it was fitted as per the instructions, and looked undamaged on delivery, but after about 10 min of viewing, the hight temp alarm sounds and the projector shuts...
Did you rest the lamp hour after replacing the lamp. It is recommended the you have to reset the lamp hour after replacing the lamp. For resetting the lamp hour do the following.
1. Power ON the projector
2. Press the Menu button
3. Select OPTIONS
4. In OPTION menu select Lamp Reset and press the enter button.
(If the lamp hour counter is at the heights level then the projector will turn OFF after some time.)
Apr 28, 2011 | Optoma EP1690 DLP Projector
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
Resetting lamp timer
Try the following:
you need to enter factory Menu.
You do so by doing the following:
1).Start the projector.
2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
Let me know if this solves your problem.
ry this:
Jun 09, 2008 | LG RD-JT30 Multimedia Projector
Lamp replacement
Hi there
You need to reset the lamp timer.
Mar 11, 2008 | 3M (EP7640ILK) Projector Lamp for MP7640
Bulb Life
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
BenQ PE5120 Multimedia Projector Logo
329 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
