Question about Dryers
GAS DRYER MY DRYER IS ONLY 3 YEARS OLD AND IS ONLY BLOWING COLD AIR WHEN I TOOK THE BACK OFF AND TURNED IT ON IT BLEW HOT AIR FOR ONLY A MINUTE THEN COLD AGAIN LOOKING INTO BACK THE LEFT SIDE IS THE BLACK DUCT LEADING FROM LINT TRAP TO OUTSIDE EXHAUST AND ON THE RIGHT SIDE IS A LARGE OVAL METAL THING ASSUMING ITS HEATING ELEMENT AND I CAN SEE SOME WIRES ANY ASSISTANCE IS APPRECIATED THANKS
THERE ARE TWO GAS SOLENOID VAVLES - YOU WILL SEE THEM WHEN FRONT IS REMOVED. SHOULD BE IN FRONT OF BURNER ON TOP. REMOVE TWO PHILLIPS SCREWS. PULL BOTH OFF. WIRES CONNECT ONLY ONE WAY. REPLACEMENT VALVES COST AROUND $16
Posted on Aug 31, 2008
1995 Buick Century blowing hot air.
A mechanic would check the system with a set of pressure gauges. If the compressor is running, the low side would read around 30psi and the high side would be around 250psi. That is how you know if the system is full of freon or not.
You may have to get a professional diagnosis to proceed. If you replace the compressor, the accumulator needs to be replaced and a vac pump is used to pull all of the air out before the freon is added.
May 07, 2013 | 1995 Buick Century
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Its blowing only cold air
Here are the break down diagrams and Replacement parts for WHIRLPOOL RGX5634KQ2 | AppliancePartsPros.com
If the Ignitor comes on and lights the first stage then when the Ignitor comes on to light the second stage, there is no gas to light
The problem in such situation is a bad coil on the gas valve. No doubt about it.
- The part number for the coil kit is AP3094251
Whas this inf. was helpful ?
Apr 06, 2009 | Roper RGX4634KQ Gas Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Dryer runs, but no heat.
get corgi registered plumber or whirlpool dont mess, dangerous, telling you problem breaker blowing obviouswly now blown appliance or conversion kit
Sep 20, 2017 | Whirlpool LGR8648 Gas Dryer
Dryers Logo
Top Dryers Experts
