Question about Technics Audio Players & Recorders
My technics amplifier su-g86 started by clicking off and leaving no sound. Now it turns on, but has no sound. The speakers are hooked up and everything else is fine. It just clicks off periodically and now no sound, but it turns on and lights up.
  • 3 Answers
Most of the time this problem is caused by bad solder joints.
All the units I have repaired all that was needed was to reflow the solder joints.
The most common place is the leads of the hybrid IC.
Usually there are very very fine cracks which can barely be seen with a good magnifying glass.
I usually go ahead and resolder most of the solder joints related to the output section.
Basically the mechanical stress of the heating and cooling causes this as well as the manufacturer trying to use as little solder as possible.
Hope this helps,
Richard
Posted on Feb 25, 2009
  • 4,234 Answers
This unit uses a hybrid amp ic RSN3305 which is probably faulty. These can be purchased for $65.73 from tritronicsinc.com
Dan
Posted on Aug 29, 2008
Speakers for Technics SU X933?
check given link for speakers
http://www.fixya.com/myhome.aspx#Answers
Jun 05, 2012 | Technics SU-G75 Amplifier
Hi I just got a Technics SU V2 amp and can't get sound from the speakers. What size speakers would suit this amp? What is the correct method to connect the speaker leads to the back of this amp,...
Being a 500W amplifier, you need to connect speakers with 300W each. The correct method to connect speakers is red terminal of speaker should be connected to red terminal of amplifier & black to black. The left side to left side speaker & right to right speaker. There may be main & remote terminals. Main speakers are the speakers at local place of the amplifier & remote for remotely placed speakers. I do have Technics SU-V85A which is somewhat similar. Enjoy! A nice piece to listen.
Oct 22, 2011 | Technics SUV500 2-Channel Amplifier
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Sep 29, 2011 | Technics SUV500 2-Channel Amplifier
Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Mar 14, 2010 | Technics Audio Players & Recorders
Hello! I have a problem with Technics SU-V2X
Well whatever is playing up sounds like it might be getting too hot to me. In any case it's something common to both channels. Just have a look on the heatsink to see if it uses a single IC for both channels, they are can cause lots of problems!
The IC might be marked STK with numbers after the letters. That is the part number too for ordering a new one.
Jan 08, 2010 | Audio Players & Recorders
Technics su-Z750 Intergrated Amplifier stays in Standby
HI...
This happens when one or more components in the power amplifier section has failed.
The protect circuit keeps large DC voltages off the speakers.
The only thing you can check for before finding a tech is that the speakers are firmly connected at both ends. If they are ok, you need a tech
PLease rate my help if this helps
Nov 05, 2009 | Technics Audio Players & Recorders
Sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Mar 14, 2008 | Technics SUV500 2-Channel Amplifier
1,121 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
