Question about Toshiba e400 Pocket PC
Record audio
Is it possible to record audio trough the headphone jack?
    Master:
  • 903 Answers
Do I understand correct that you want to use the headphone jack for recording ? That´s impossible, The headphone jack in just for output signals. It´s not possible to use this one for recording sound.
Posted on Sep 11, 2005
SOURCE:
Question (not a "problem") -
Yes, you can. You need a cable (A 3.5 to 3.5 audio jack - you can buy it for a few bucks at your local store) that plugs into the Microphone jack in the computer and the Headphone jack in the cassette player. After that, use a recording software (Such as AudaCity) and select the input microphone as the recording device. All you have to do, is press Record in the software and push play on the player. Good luck and best regards,Yuri.
Jun 04, 2011 | Arcsoft ShowBiz DVD 2 (3265)
I have a cheap Samson microphone (package said designed for karaoke, not professional). It says R10S on it. It just plugs into the mic jack on the side of the laptop. I want to use it for online...
You can't record two audio sources at the same time without a high end soundcard, your computer will automatically switch to the mic input when you plug it in. The best way to do what you want is to use a program like SoundForge to record the music first, then record your voice while listening with headphones. Then you can export both tracks to an mp3 or whatever format you need. Or, you could possibly record the music, put it on an mp3 player, and play it over a stereo system while you sing along, and record the whole thing at the same time to your computer.
May 12, 2011 | Computers & Internet
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
I plugged in a microphone to the phones jack but it is not recording onto the tape.
This is a car stereo, right? You can't record on car stereos. The phones jack is for headphones.
Jan 25, 2010 | Car Audio & Video
How do I record from a CD onto a tape?
Two ways. You can put the audio out leads of the CD into the line in of the recorder. However you will have to listen to the recording by connecting headphones to the Recorder's jack socket.
The most common way is to connect the recorder to an amp and the CD to the same and with the cd playing back press record.
In both cases you must set the record level control so that sound on the VU meters peaks at loudest parts at around 0db, rarely going over (into the red on LED type meter).
You will need a 4way RCA type phono cable, the better quality types will give you a better sound. Connect the playback jacks via the output sockets of the recorder to the tape inputs of the amp, vice-versa for the record jacks.
Dec 01, 2009 | Pioneer Audio Players & Recorders
Line in / Mic jack help
So we're talking PC here, right?
I don't understand what you want to record. Going from the PC Headphone jack to the PC Line IN might be unwise in order to prevent a feedback loop. External (non-PC) source and PC MIC might work but you would probably want to monitor it on headphones again because of possibe feedback.
Does your MIC work?
Right click the speaker icon again and select Adjust Audio Properties or open Control Panel and select Sounds & Audio Devices. Select the box to place the icon on the Taskbar for future use.
Right click on the little speaker icon in your Taskbar and select Open Volume Control, if it's there. From there you're on your own. I have a sound card so I don't know what you will see. Look around, there may be a bunch of audio outputs and inputs with Master and individual volume & balance controls plus one for your Mic. Make sure it's not muted.
Apr 21, 2009 | Audio Players & Recorders
I have a Sony ICD-SX35 recorder which my iMac will not recognize. Any clues out there???? I need to convert the dvf files into MP3 or WMA format but that can't happen before my Mac recognizes the...
I took the advice of one of your correspondents by connecting my Sony ICD-SX365 recorder to my iMac with a simple audio cable by inserting the output jack in the recorder's slot for headphones and the input jack in the iMac's slot for microphones. I used the freeware program Audacity to import the track onto the computer and Switch to convert the file to mp3.
Apr 15, 2009 | Sony ICD-P28 Digital Voice Recorder
Plugging in keyboard
MIDI only carries digital information, not audio. Midi is used to communicate patch settings and note value information. If you want the recording to know the note value, then you should use midi. This is useful if you want to do things like adding rythm tracks, etc.
If your keyboard has audio/line out (as opposed to headphone out), use that, as it is matched much better in impedance. If it doesn't have audio/line out, then you can use the headphone jack, but you will have to turn the attenuation way down because the headphone jack impedance is much higher. This will tend to distort on the recording if you are not careful.
The first thing to know about digital recording is that distortion is much more of a problem. I won't get into the theory of this, just know that impedance mismatching is more of a problem with digital.
Sep 08, 2008 | Tascam 2488 Portastudio Multitrack...
Line Recording with H5500
i think that audio jack is for headphone-microphone combined (those cable plugs have a three black lines , top for left audio, center for right audio, last line for microphone) so you can use a headphones with mic directly with this 5500. the mic is i said before is the last line. what you need is a monophone plug. (mono mic) i dont think stereo mic will work.
Sep 12, 2005 | HP iPAQ H5555 Pocket PC
Toshiba e400 Pocket PC Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
