Question about Xerox Office Equipment & Supplies
WE CAN'T FAX, PRINT FROM OUR SYSTEM OR SEND QUOTES, WE ARE 20 PEOPLES NEEDING THIS MACHINE TO WORK, AND IT'S NOT WORKING : IT SAYS: "NETWORK CONTROLLER NOT AVAILABLE" PLEASE NOTIFY MACHINE ADMINISTRATOR ******* WE URGENTLY NEED SOME ASSISTANCE ************
  • 239 Answers
Yes, this could be a ESS or any of the piggyback boards.
Not an easy solution.
Call the Xerox Service Representative to repair the machine.
Posted on Oct 16, 2009
    President:
  • 2,072 Answers
I don;t know what model you have but, with the message coming up Network controller not available there are several things that can be the problem.
On some machines, where the network is contained in a box attached to the back of the machine, often times, actually frequently the circuit boards will just work themselves loose and need to be reseated.
The, What Xerox calls the ESS, or network circuit board can be bad. On some other models the network hard drive is defective. Or the network firmware ( software that operates the network) may be corrupted and not loading. The best thing you can do is place a service call to have it resolved since that normally is not a simple issue.
Posted on Aug 30, 2008
Faxes will not go through, says
Try changing your resolution to FINE or SUPERFINE Make a copy to verify the FAX MFC scanner operation.
Apr 11, 2012 | Brother IntelliFax-2820 Laser Fax
I'm having a problem with my HP "1020 Series" Fax machine. When it's recieving a fax, "Recieving P1" appears on the display for about 10 seconds. The display will then GO BLANK,...
I do not know about this machine but one of the most noted problems for machines is software and firmware updates needed to keep them up to date with computer systems they connect to.
A visit to HP to download its latest software may well help you in this case, start with the drivers which can cause untold issues if outdated.
Hope it helps.......
Jun 04, 2017 | HP 1020 Plain Paper Thermal transfer Fax
Sending fax error message."Phone
No. Most of the time this "phone line error" can be caused by the telephone connection or issue on the phone line where the fax machine is connected.
Hope this will help.
Mar 27, 2011 | Office Equipment & Supplies
We have a fax machine Panasonic KX-FT21. everytime we turn it on, it prints an Important message which says "PLEASE SET-UP DIAL UP MODE". Then the LCD keeps on showing the wrong time and the...
You need to replace the backup battery located on the main printed circuit board. These are usually soldered onto the board but some have receptacles which make replacement easier.
Feb 23, 2011 | Panasonic Panafax UF-595 Plain Paper Laser...
Hi, I have a Fuji Xerox 3200MFP. I can fax with no problem, scan with no problem. But I can not print or copy - anything that requires printing. The Status Window gives me "Printing... Please...
Most likely it's the driver. Try going to the Fuji website and see what drivers are available. It's possible that the driver your using isn't designed to work with your operating system (such as designed for Windows XP and your now using Windows 10, etc.)
Jun 16, 2017 | Xerox FaxCentre F12 Laser Printer
I have an Okifax 2350. It sends faxes fine but won't print. The screen says "Paper Jam" and "Replace Paper." I am fairly certain there is NO paper jammed anywhere in the machine. ...
Yes, it could be a sensor. Remove the toner and drum assys as well as the paper cassette and look for the sensor actuators. Usually black plastic pieces that will move a bit. Blow them out with air and see if that doesn't help. Let me know.
Jan 09, 2011 | Office Equipment & Supplies
Need to send an overseas fax - how do I get the "+" sign before the fax no?
I don't know what you mean about a "+" sign. There is no sign necessary. For example: You can't do it on a regular telephone call either.
If you're having trouble figuring out the dialing codes, this link may help:
http://www.timeanddate.com/worldclock/dialing.html
May 09, 2009 | Office Equipment & Supplies
159 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
