Question about RCA Audio Players & Recorders
My RCA RS2622 sound stopped working.
I was extending one of the speakers when I (stupidly) let the bare positive and negative wires touch, while the stereo was turned on and playing. My dad is a electronics wizard and is stumped by this one because the speakers are fine as is everything else about the radio, and even the headphone jack works, but puts out no sound to the speaker jacks. I've researched this a bit and noticed other people have the exact same problem! (not caused by bare wires touching that is) My question would be do you think whatever happened could be repaired at home, a mission for my father, any good ideas for him?... or should i/is it even worth to send it on somewhere to get repaired?
Ive had the same problem with a RCA stereo i use. There areinline fuses in the amplifier section that will blow if something like this happens. If one blows it will make no sound. Replacing these fuses should fix this issue.
Posted on Jun 25, 2013
  • 4,234 Answers
I'll need to look up your specific model to be sure, but I believe that the speaker outputs come from an amp pac. The headphones are driven by an opamp IC. The outputs are blown on this. If you can solder, you should be able to repair this. I'll look up the parts required and get back to you.
Dan
Posted on Aug 29, 2008
  • Thugkim Mar 27, 2011
    Have the same problem, but the headphone jack also does not work. Any tips? Note : I'm not an electronics wiz!
My amplifier for my subs is tied into my rear speaker wire with RCA adapters hi touched the RCA adapter accidentally to the speaker box positive negative and it arced now I have no sound from my radio
You probably trashed the output transistors in the radio. You may have lucked out and only blew a fuse. If the fuses are good, then say hello to a new radio.
Dec 17, 2015 | Cars & Trucks
My panasonic dvd stereo system sa-pm91d when the volume is turned above 25, it plays distorted sound, it sounds like I have incorrectly tuned a radio channel even when using the auxiliary input
Hi Gusma,
If you have Distorted sound.
    These may be the causes of the problem:
  • Make sure the speakers wires are properly connected.Check the color codes, be sure they are rightfully followed.
  • - Shorting (bare wires touching) of positive and negative speaker wires.
  • - Using speakers with an impedance lower than that rated for this unit.
  • - Straining of the speakers through excessive volume or power.
  • - Using the unit in a hot environment without proper ventilation.
I am also including a link to the User Manual. Read it thoroughly.
Best of Luck,
JP
Panasonic SC PM91D Operating Instructions Manual
Jun 26, 2015 | Panasonic Audio Players & Recorders
What is the proper way of connecting my two speakers to my PIONEER M-90 Amplifier?
As with any amplifier...
Typically:
Connecting the speakers
Each speaker connection on the receiver comprises a positive (+) and negative (-) terminal. Make sure to
match these up with the terminals on the speakers themselves.
Make sure that all the bare speaker wire is twisted together and inserted fully into the speaker terminal.
If any of the bare speaker wire touches the back panel it may cause the power to cut off as a safety measure.
Feb 06, 2011 | Audio Players & Recorders
Mazda 323 1996 wiring
this is for 1996 mazda protege i hope this can help
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Pink/Black
Car Radio Ground Wire: Black/Yellow
Left Front Speaker Positive Wire (+): Blue/Orange
Left Front Speaker Negative Wire (-): Violet/White
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Yellow/Red
Left Rear Speaker Positive Wire (+): Orange
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Green/Black
Right Rear Speaker Negative Wire (-): Green/Orange
Mar 27, 2010 | Mazda 323 Cars & Trucks
How do I hook up the bare wires speakers to the back, sound is coming out not good.
Sounds to me like you might have the polarity reversed. Meaning you might have hooked the positive to negative and the negative to the positive. Positive will will be red negative will be black on your receiver. On the speaker wires negative will always be solid black. Positive could be solid red, black with a red stripe, or black with any color stripe. Make sure you have solid black hooked to black and the other hooked to red. Hope this helps:)
Nov 30, 2009 | Insignia 200W Stereo Receiver
I want to change my front speakers on my 1999 Pontiac grand prix and i need the color code for the positive and negative wires. my car does not have the Bose system. Thanks.
cut the wireharnis clip that goes on the stock speakers off the wire with black strip is the negative the other is the positive or just test it by touching the bare wire to the positive and negitive on the new speakers it only works 1 way
Sep 11, 2009 | 1999 Pontiac Grand Prix
Subs dont work
To test speakers.A. Unplug speaker wires.
B. connect a 9volt battery to each speaker,touching one wire to the negative and the other to the positive breifly. The speaker should extend outward or inward, simulating the pumping of the cone. Depending on the polarity of the DC voltage hooked to the battery.
That's why it is important to wire the speakers correctly. Pos to Pos Neg to Neg.
You should know if the speakers or wired in series or parallele.
Google speaker wiring. Very informative.
Aug 12, 2009 | Harman Kardon HK695 Computer Speakers
No sound to speakers hooked to RCA jacks.
you have the wires mixed up. the positive wire is hooked into the negative, rechech your wiring
Apr 13, 2009 | Dual XDMR-7700 CD Player
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Problem with hifonics 1505 class d mono
The positives are connected together and the negatives are connected together. The two pairs of terminals are for convenience. You'd connect one speaker to a pair of positive/negative terminals and you'd connect the other speaker to the remaining pair of positive/negative terminals.
You need to confirm that you have a good signal feeding the amp. If you have another amp in the vehicle, swap the RCA cables between the amps to see if it makes a difference.
You also need to confirm that the speaker are working properly and that there are no broken connections in the wires. If you disconnect the speaker wires from the amp and touch the wires across a D-cell battery (for a fraction of a second), the speaker should pop. if it doesn't, check the wiring to determine why.
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
625 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
