Question about Sony UVW-1800P VCR
Sony UVW-1800 BetaSP deck
I have a 10 year lod deck that works great excellent except the lights have become very dim and sometime go on and off intermitantly. What seems to be the problem and how do I fix it?
    Problem Solver:
  • 17 Answers
If it still works the capacitors on board attached to the display are going bad. Replace any that have corrosion on the solder joints and clean up the corrosion while your at it. If it quit working altogether there is also a fuse or ICP on that board that typically blows too.
Posted on Jan 07, 2014
    Champion:
  • 221 Answers
Defective lcd module which provides voltages for all the front panel displays. have replaced several.
Posted on Oct 23, 2008
I have a UVW-1800 VTR. Power supply has click noise, it doesn't start up. Does anyone know the UVW-1800 power supply problem? Thanks,
Did you ever get a reply/solution to this? We have just have the same thing happen to our deck today.
Thanks
Feb 14, 2010 | Sony Televison & Video
Sony UVW 1800 display isn't working and I need to sell it
sony part no.1-810-374-11 s indicator tube module,fluores. This is information about part you need to fix that.You will be able to replace that,but you need to disconect front desk ( there are two screw from left and right said,and two above ). It`s little bit hard to remove that, but you will find the way. Audio level meter ( modul fluores ) have two screw from front said,pull it trow yourself,and you will see two flat cable. When you disconect them,that modul fluores will be free.Take off that protection ram and put on new modul. And put everything back on right place.Board can be fixed if you have any experience.
Nov 30, 2009 | Sony UVW-1800P VCR
No readout on front panel. UVW-1800
No front panel readout on a UVW-1800 is caused by the audio bargraph display failing. This display has an auxiliary power supply in it that provides power to the front panel display.
Oct 15, 2009 | Sony Televison & Video
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
Jul 02, 2009 | Sony UVW1800 VCR
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
Mensaje error 02-395 on a Sony BETACAM UVW 1800
error code 02-395 points to a problem with one or both reel motors. a good technician should be able to fix this easily.
Jan 21, 2009 | Fuji M321SP Betacam Tape
Digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
Dec 29, 2008 | Sony Betacam SP Small Videocassette 30...
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
Sony UVW-1800P VCR Logo
328 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
