Question about LG Refrigerators
Lg not working
Lg freezer over fridge model not working or can say erratic working
light come on but is less cool
  • harpreetot Aug 30, 2008
    my model no Lg GRS592QVC
    HARPREETOT
  • harpreetot Aug 31, 2008
    indeed model no is GR-S592QVC
    IT IS freezer over fridge model,
    now freezer is fine and cool but lower portion fridge is not cool enough,, even the temp lights at the back wall are playing up,, i increase the lights so that temp cools and ----they r now not working,,,,
The compressor cuts off after a minute of running. I'll unplug it for a few hours, plug it back in and the same thing happens. What do you think this is? Thermostat? And where is the thermostat located on an lrsc 26912tt? How do you go about changing this?
Posted on Jun 22, 2011
  • 1,543 Answers
Please always post an exact model number. That info helps us so we can give much more specific help, including looking up any service bulletins or parts. Regardless of the configuration of freezer location to fresh foods compartment, as a general rule when the compressor is running the evaporator fan (in freezer) and the condenser fan (near compressor) should also be running. If all OK, look for frost build up on freezer wall (usually the back wall) indicating a defrost problem (most often a defrost heater failure, but can be an electronic control board or other component) Check that the door gaskets are sealing. Is there an ice maker? Do an "ask me" or look for me for an on line chat with more details if you have further questions.
Posted on Aug 29, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Aug 30, 2008
    I cannot find that model number anywhere. "GRS....." sounds like a Fridgidaire number. LG top freezer refrigs were model #'s like LRTN19320SW or LRBP1031W, etc. It looks like all LG brand refrigerators (regardless of style) model numbers start with the letter "L". Please double check model number. Get the number off the sticker on the refrigerator, not off the book.
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Hi there I have an LG Icebeam Door Cooling fridge that doesnt seem to be working correctly. The fridge is not that cold and the freezer is defrosting on the top section. The light is on and it seems
Find your model # and put it in the search box here: http://www.lg.com/us/support . Once your fridge is showing, there is great troubleshooting info available. Also, armed with the model #, we can actually give you pertinent advice!
Nov 24, 2014 | LG Refrigerators
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
LG 262SQA Model fridge cannot cool
That does not look like an LG model number, but regardless, it sounds like the defrost system is not working, allowing frost to build up and block air flow over the cooling coils in the freezer (where all the cooling for the entire refrigerator takes place). Take back panel off inside freezer, melt frost / ice with a hair blower. Test for continuity through defrost heater and replace if "open". If it was OK, problem could be deftost control, or as simple as a door not fully closed at some time, allowing excessive frost build up.
Nov 18, 2011 | LG Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
MODEL LRS 206 GP FREEZER IS WORKING WELL AND THE FRIDGE IS NOR WORKING WHY ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | LG LTC22350S (221 cu ft) Top Freezer...
Fridge not cooling
You most likely have a thermistor that needs replacing. Can you tell me the the temp. in the fridge? Most LG fridges have a 1 year warranty with extended warranty on some parts. If you could provide the model #, I can look into it further for you.
Feb 03, 2009 | Refrigerators
I have an LG fridge top / freezer bottom which I purchased exactly 3 years ago. The fridge has stopped cooling, although the inside light stays on. Also, the freezer is still working perfectly. Firstly,...
Most LG fridges have a 1 year warranty with some components exteneded, such as the compressor or sealed system repair. Those are usually 5 years or long, depending on the model.
Can you tell me the temp. in your fridge please? I have a strong suspicion that it may just be the thermostat.
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
194 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
