Question about Toshiba e400 Pocket PC
Pocket PC e400 en Sandisk WiFi
At a local store I've seen they sell SD WiFi cards. The only thing you need is an SD/IO enabled SD slot. Since I want to be sure it'll work I would like to ask if this should work since Toshiba only offers Bluetooth as an option...
    Master:
  • 903 Answers
I have bought the Bluetooth Option Part for my e400. It was an "PC Bluetooth SD Card2". In the specs of the Bluetooth Card is an SD/IO enabled SD Slot required for the Card. So I think your Wifi will also work.
Posted on Sep 11, 2005
My TransFlash 2.0 memory card doesn't show on my lap top
First, the basics...
There are three kinds of SD cards (SD, SDHC and SDXC). Not all computers are designed to accept all three types. SD cards can store up to 2GB of data, SDHC can store up to 64GB of data, and SDXC cards can store up to 2TB (terabytes) of data. If you are unsure which types of cards your laptop or computer will accept, visit the manufacturer's web site and look for the specifications for your particular model to be sure. It's tempting to want to buy an SD card with a large data capacity, but it's wasted money if your computer will not work with the high capacity card.
Make sure you have inserted the card correctly (and fully). The card is 'keyed' (with a notch in one corner) so it should only fit into the SD card slot one way *easily*. Obviously you can try to force the SD card into the slot the wrong way, but the position which goes in the easiest is probably the right way. Some devices have a symbol beside the slot indicating which way the card should be inserted. Be careful, though. It is natural to think the the card should be inserted with the manufacturer's label facing up, but I've seen devices where the card should be inserted 'upside-down', contrary to what I thought.
If you are using a Windows computer with a 'recent' version of the operating system (Windows Vista or later), the computer should recognize the card (as a newly attached piece of hardware) and show the card as a new drive letter when you open the Windows Explorer program to view your files and folders.
If the card is new, it should be formatted already and can be used immediately, BUT...your computer may need to have a driver program (software that enables the use of specific hardware items). My laptop, for example, uses a driver from Ricoh to enable the SD card slots, and that driver had to be downloaded from the HP support site and installed before my SD card slots would recognize SD cards.
If you know you have the correct SD card device driver installed, have an SD card that will work with your computer but still do not see the card in Windows Explorer, you can check in the Windows Device Manager to check its status. You can also use the Disk Management features of Windows to check what drive letter has been assigned to the drive. If the SD card has been assigned a drive letter already used by another drive, then it will not be available in Windows Explorer.
If you think any of these last problems I mentioned are part of your issue, reply here and I can see if I can help you further.
Apr 18, 2016 | Kingston Electronics - Others
HP IPAQ H4150 + Memory Cards
Your HP IPAQ has a SDIO expansions slot...
which is a new technology.
so will have to use an SDIO card ...
this is a secure digital IO card.
hope this will solve the problem
Oct 30, 2008 | HP iPAQ H4150 Pocket PC
Says sd card error
Are you sure it's an SD card? Even though SDHC cards will also fit into the slot, they will not work in the A540. If the card is larger than 2GB then it will not work.
Feb 03, 2013 | Canon PowerShot A540 Digital Camera
Get wifi to work on Panasonic Toughbook CF-29 PC Notebook
if you don't have a card, you can always buy a pcmcia card if it has the appopriate slot. if not you can buy a usb adapter for it. make sure that you have the physical on/off switch set to on
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 05, 2012 | Panasonic Toughbook CF-29 Notebook
What's an SD card ?
An SD card is a "secure digital" card designed to store data and to enable the transfer of data between devices equipped with SD Card slots. Think of it as a portable card that stores information
Feb 21, 2011 | Cameras
How Do I/Where do I put this thing in my phone
Stick the microchip into the adapter(s) and insert it into a sd slot on your computer if you have one. If you dont have an sd slot, they sell external systems for sd cards at any electronic store that carries computers such as best-buy. This should FixYa!
Jan 27, 2009 | SanDisk 1GB microSD Memory Card
Direct Internet Connection with Matsunichi i-mat IP3230 Pocket PC
if you are telling me that it has already builtin wifi,you dont have to buy it, those people who doesnt have built in wifi can use sd card for wifi,im sure it will fit to yours,because SD card has standard size..
Jul 04, 2008 | Matsunichi i-mat IP3230 Pocket PC
Wifi support t5
If you want to get WiFi, the only WiFi SD card available for the T5 is the Palm WiFi SD card. No other WiFi card compatible.
The SD card fits into the SD slot, but the card is longer than standard SD cards, so part of it extends out of the slot. This is the antenna for the WiFi radio. Also, you must install the drivers for the card or else it won't work properly. Drivers are available for free download at Palm's site. Linux will not work either without the card, sorry.
Mar 29, 2017 | Palm Tungsten T5 Handheld
Cannot see any SD card in expansion slot
The first thing to try is a soft reset while the card is inserted.
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
SD GPS
I have read some Information about Toshiba PDAs. There is a technique called SD™ IO card. In the technical specifications I found this Info: 1 x SD™ card slot (supports SD™ memory card, SD™ IO card, MultiMedia card) So when SD™ IO card is the same as Bsquare SDIO Now! tecnique...
Sep 08, 2005 | Toshiba e750 Pocket PC
Open Questions:
The Best Cheap Cloud Storage and Backup Services ' DataAlign Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud Backup For Small Business Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Sep 18, 2018 | VIA Computers & Internet
See all Toshiba e400 Pocket PC Questions
Toshiba e400 Pocket PC Logo
199 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
