Question about PC Chips M789CG (M789CGVIA2000) Motherboard
Onboard graphics Hi, I did try disable in bios but there is no "peripherals" option nor anywhere obvious to me, to disable vga / on board. PCI is enabled. Is it possible that there are jumpers to be moved or removed ? Again, many thanks for your help
    President:
  • 2,961 Answers
It will be there somewhere, look for similair to graphics/hardware, make sure you open up the menus sub menus
Posted on Aug 29, 2008
How to disable on-board VGA card my machine Gateway E-4620d I have installed a External NIVIDIA Graphics Card into my machine Gateway E-4620d how disable on-board VGA
In the bios there should be a tab for onboard devices. Just scroll through the tabs until you find one called VGA. Cycle through the options and pick disable if the option is enable/disable only selections....or pick auto if the choices are either onboard or pci-x , pci, etc.....
Jul 25, 2012 | Gateway E-4620d Desktop Cpu Dual Core...
How do I disable my onboard graphics on my Acer Aspire T160? I want to add an HD 512MB pci express graphics card.
You can disable the onboard VGA card in BIOS, to do so
keep on tapping F2 button as soon as you hit the power button, under the CMOS search for VGA or onboard VGA and click Disable.
Thanks
Jitha
Dec 25, 2010 | Acer Aspire T160 PC Desktop
Im trying to install agp...how do i disable the on board vga
Hi there.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Jun 04, 2009 | HP Compaq Motherboard
Want to disable onboard graphics to install and use pci vga card
During the initial boot sequence (as soon as you turn your PC on), try pressing <DEL> button (or F2 or F10 - you will see info on the bottom of the screen stating something like "Press _____ (del, F2, F10) to go to Setup..."
This will take you to BIOS, main setup panel for your PC.
There you can find and option for switching your main GFX card.
Options will be something like: onboard, pci, agp. You should choose
PCI.
Try doing this after you insert your new PCI gfx in your computer.
Good luck,
Milan
Jun 01, 2009 | EliteGroup P4VMM2 Motherboard
Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
Mar 07, 2009 | MSI RC410M-L Motherboard
Disable onboard video of presario 5105rsh desktop pc
u can disable the the on bord vga in bios
enter in bios then u see in ide or advanced vga disable it then save settigns .
Jan 29, 2009 | Computers & Internet
Disabling onboard video on Acer aspire m1640
you cannot dissable the on-board graphics in the bios, in the graphic options you must choose which port you want to use, if you have a pci express card then chose pci as the primary graphics, press ok then F10 your pc will reboot and the on-board vga won't load up in windows
good luck
Nov 14, 2008 | Acer Aspire M1640 Refurbished Intel...
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
Replacing the onboard graphics card
Friend,
There are three PCI slots on yoyr motherboard. You can add any PCI VGA card to your board. After adding the VGA goto BIOS setup and make ON BOARD VGA DISABLED.
Thanks & Good Luck
Iqbal
May 27, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
PC Chips M789CG (M789CGVIA2000) Motherboard Logo
143 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
