Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Programmable Thermostat Model 43157
I installed a Model 43157 programmable thermostat.
It seems that my a/c runs long and then doesn't come back on for awhile. It feels like it gets so warm and then it comes on, runs long and gets real cool, then it doesn't come on again for awhile until it feels warm
  • qt_jess17 Sep 03, 2008
    this is the exact same problem we are having..I thought that it was supposed to keep it at the set temperature but it seems that it cools for a long time gets freezing then it turns off waits until it's steaming hot and we are sweating and then turns back on and starts freezing the house again!!
    We've tried changing the temperatures and programming it but perhaps we just aren't doing it right...anyone have any solutions? Please help...we have a newborn and the temperature changes are giving her a stuffy nose!
On my Hunter model, there is a "Span" setting that allows you to change how long the AC/Heat will run before it turns off. Basically, it sets the acceptable range (above and below) your temperature setting. To access this press both the up and down arrows and hold them. "Span" should show up with a number (1,2, or 3). For your problem, change the setting to 1 so the AC will run shorter, and more frequently to keep the temperature more constant.
Posted on Sep 05, 2008
My Quickstat has stopped working completely. not a gfi reset issue, but zero display. there is still power to unit. Im guessing that I need to replace unit.
Raychem QuickStat-TC Installation & Operation Manual
www.manualslib.com > Brands > Raychem Manuals > Thermostat
View and Download Raychem QuickStat-TC installation & operation manual online.QuickStat-TC Thermostat. QuickStat-TC Thermostat pdf manual download.
Raychem - QUICKSTAT-TC, Programmable, Thermostats ...
www.platt.com > ... > Floor Warming > Thermostats > Programmable
$144.29 - ‎In stock
Raychem QUICKSTAT-TC Programmable Thermostat Programmable Thermostat, 120/240V, 16A, GFCI, 4 Programmable Events per Day.Missing: tyco ‎working
Raychem Quickstat Floor Heating Thermostat Installation ...
Dec 26, 2015 | Raychem by Tyco QuickStat-TC Thermostat
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Only fan turning on ? model th8320
If you have not changed the configuration of hte thermostat, it will still try to operate as a programmable model. You can configure this thermostat as a non programmable type. If you have the manual for this thermostat, the process is located on page 22, if not, you can get a copy of it on my company website:
http://www.emshvac.com/Manuals/
The file is TH8320.pdf just either click and it will open or right click and select save target.
Sep 13, 2009 | Honeywell Electronic Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Thermostat does not follow the setting
If the thermostat is a digital /programmable you may want to recheck program to see if it has changed or been changed. If thermostat is not digital then it is prbably warn out and need replaced.
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Programmable Eletronic Thermostat model RTH230B
There are so many products, we cannot help without the model no. Try typing 'Honeywell programmable electronic thermostat' into google and searching for an image of your thermostat, then get the model no. Then you might be able to get some help.
Dec 20, 2007 | Honeywell Programmable Thermostat Heater
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
771 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
