Heating & Cooling Logo
A
Anonymous Posted on Jul 22, 2011
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not cooling,any suggestions why the compessor fan has all of the sudden stopped working?
Anonymous
Level 1:
Guru:
  • Contributor 683 Answers
  • Posted on Jul 22, 2011
Anonymous
Contributor
Level 1:
Guru:
Answers
683
Questions
Helped
136490
Points
21
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
I have an Amana heater/airconditioner (Prestige I think) that is not cooling. The outside compressor fan was not spinning, so i I changed the capacitor on the unit. It now spins, yet vent air not cold
If that fan stopped your compressor overheated, shut off on thermal overload. Carefully cool compressor with water hose and restart. If the big copper is cold ,small copper warm, compressor is running. Check capacitor on compressor
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Amana ptc123 UNIT STOP WORKING
Indoor or outside. Im pretty should the compressor has gone. If you turn it on does the indoor fan and outdoor fan work but not cooling . or does it not turn on at all.
have you checked your fuse box.
1helpful
2answers
Amana Prestige II air conditioner. The fan unit on the top of the ouside unit stopped spinning. I gave the fan a good push and it started spinning (and continues to spin) however the air now blowing into...
You need to replace the fan capacitor. Your compressor is probably in thermal overload you can cure this by turning off the disconnect your ac voltage and taking a cool water hose and running over the top of the compressor for a while. Then turn your disconnect back on and listen and feel of the big copper line to see if it gets cold and also listen to see if the compressor kicks on.
Liquid line is cool coming from condenser indoor air not cold enough. Unit runs constantly at temps of 90 to maintain 80 inside
If the compressor is running at 90 there should be hot air coming out of the condensing units fan, if not it could be damaged valves in the compressor especially if the suction line is colder than normal like ice cold.
Obviously if the compressor is not running then you have other electrical problems.
Compressor wont turn on. fan runs central unit
first check you thermostat settings and make sure that it is on a cooling setting if ok it can be the fuse that sends the power to the outside unit if fuse is ok it can be the capasitor for the compressor if ok you may have to check the compressor for open windings or ground fault so you will have to replace the compressor or the relay which is after the thermostat
1helpful
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
2helpful
2answers
Good noon! I have an Amana prestige II, but the fan for working compressor keeps running out of door when fan stop in the attic.
This sounds like your contactor is fused shut. Normally the contactor disengages when your unit turns off, but if the unit is getting older and runs for long lengths of time the metal will actually meld together. I would have someone replace the contact switch. Good luck
Mistral mss20 split a/c only cooling somtimes 4 about 10 m then
Sounds like your unit may be a bit short of refrigerant and the compressor is therefore cutting out on low pressure.
2helpful
3answers
Ptac fan keeps blowing
Reset the unit to factory setting by take the master switch off of 10 sec.
Then press and hold the cool and heat button down while turning the master switch back on.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
