Question about Apple iPod MA446LL/A MP3 Player
Sade face What doyou do to remedy the "sad face" icon that appears w/ www.apple.com/support /ipod
  • 28 Answers
The reason a sad face appears is because the hard drive is not being read for what ever reason. Unfortunatly 90% or so need the hard drive replaced. Try these first, with the face down, try to start up the ipod while tapping on the back. A hard drive is designed exatly like an record player and sometimes the arm gets stuck. Also a soft reset (Menu and Middle button at the same time for about five seconds) can often jiggle the arm free. I have also seen low battery's cause sad faces but you would need a wall charger to test this and you would have seen signs of a low battery. Hope this helps.
Posted on Aug 29, 2008
My ipod does nothing just shows a sad face
The "sad" iPod icon usually indicated that the iPod is having trouble connecting with a computer. This is, in most cases, not a serious issue and can be resolved with a few easy procedures. In most cases the data on the iPod is intact, even if the sad icon was displayed.
Verify the iPod has a charge. If in doubt, allow it to charge for 30 to 60 minutes. Do not remove charging cable. Toggle the Hold switch to the Hold position and back. Then press both the center (Select) button and the Menu (upper part of wheel) for up to 10 seconds. Release the Select and Menu buttons when the Apple logo appears, and quickly simultaneously press the Select and Play/Pause (bottom of the wheel) button. Switch from the electrical plug to a computer connection (if necessary) when the Disk Mode screen appears. The screen should change to the normal "Do Not Disconnect" update screen. Contact Apple about finding a repair service if the iPod will not go into Disk Mode.
Feb 03, 2013 | Apple iPod Audio Players & Recorders
SAD FACE ICON
In most cases, the sad iPod icon indicates a hardware issue. If you are able to force iPod into Disk Mode, then it may not be a hardware issue, and you should try to restore your iPod with the latest software.
To force ipod into Disk mode http://support.apple.com/kb/HT1363?viewlocale=en_US
To restore ipod http://support.apple.com/kb/HT1339?viewlocale=en_US
Jul 19, 2009 | Apple iPod nano
My ipod says www.apple.com/support/ipod
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
could be just your hard drive cable
Jun 14, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Flashing icons while charging... am I really charging?
If the iPod is showing the "Sad iPod face" icon, this means that the hard drive inside the iPod (located on the logic/circuit board) has died/failed and needs to be replaced. If you plan on replacing this part, you may also need to purchase and solder a new battery to the iPod logic board if you were to do it yourself.
May 26, 2009 | Apple iPod nano
Will not turn on
If the sad face appears on your ipod, it means it is broken. It needs to be taken into Apple to have it repaired or you might have to buy a new one.
Sep 14, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Sad face on the screen of my ipod..
really bad!!!!!!!!!!!!!!!!!!!!Broken now...
Aug 22, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod shows sad face and folders
the sad face means there is a software / hardware side fault witch needs service.
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore…
www.apple.com/support/ipod/five_rs/
If they dont work you will need to send the ipod in for service.
Apr 19, 2008 | Apple iPod 4th Generation MP3 Player
My ipod shows a sad face
Hopefully your ipod is still under warranty, because this is indicative of a hardware problem.
You could try to force it into disk mode and do a restore, if that doesn't work then it needs to be sent in for repair.
http://docs.info.apple.com/article.html?artnum=61771
Jan 25, 2008 | Apple iPod 4th Generation MP3 Player
Sad face icon
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
166 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
