Question about Kenmore Elite 45986 Front Load Washer
Kenmore washer bought in 2002 heavy duty
Machine makes a loud noise and jumps sideways when changing cycles
  • 639 Answers
Peace Friend,
ngfam1 At your service!
You did nothing to cause this! Things wear out! So is life!
Sounds like the coupling between the transmission and the agitator is broken!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Sep 02, 2008
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Washer stopping abruptly at end of spin cycle.
Hi, it sounds like maybe some dust has gotten in the basket drive pads causing it to stick. Has it been happening long? Sometimes it will work its way out. Try turning the tub with your hand clockwise. You can also put a heavy load in the washer (wet) and let it get to a high spin. Then open the lid and see if it starts stopping slower.
If this doesn't clear its self up, you will need to change the basketdrive.
Please let me know if this has helpped.
Thanks
Vic
May 17, 2009 | Kenmore 15864/15862 Top Load Washer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 82110 - Loud Noise
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Mar 31, 2009 | Kenmore 22422 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
Kenmore series 80 washer only works right on hevy duty load
CHECK SEE IF MOTOR IS SEIZED BY TIPPING MACHINE FORWARD AND SEE IF YOU CAN TURN THE MOTOR BY HAND. IF MOTOR TURNS FREELY , YOU HAVE A START CAPACITOR PROBLEM.
FXIT
Nov 20, 2007 | Kenmore 22422 Top Load Washer
Slow cycle making a loud CLACKING noise???
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Apr 08, 2007 | Kenmore 45981 Washer
Kenmore/works on one cycle only
that machine have somes burn contacts on the timer replace with a new one and that is...good luck
Aug 07, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
