Color My tv mixing colors-green were go blue....
No button
Posted on Aug 30, 2008
    Genius:
  • 2,920 Answers
You need to re converge the set...theres should be a convergnce button on the remote
Posted on Aug 29, 2008
Why does my sony 45 inch screen have mostly green color?
the color tv display used mixing of three colors, (red, green and blue). it lost one color, coomon problems: lose contact of base of picture tube or its wiring, sockets, capacitor dead in rgb section, dead video ic
Oct 05, 2014 | Sony KP-FX432M91 Projection TV 43 WEGA, 3D...
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
HI, when printing in colour the blue appears as partially green
Usually this happens in inkjet, when you have a mix of the colors int he cartridge.
so, inkject usually have 3 colors, Blue, Yellow, Red.
If yellow color finds it's way towards blue, then instead of blue, you will see green.
Solution: change cartridge.
Aug 01, 2011 | Office Equipment & Supplies
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Half of my tv has a green tint to it. what's wrong with it
you may have the 3 componet cables mixed up. it is easy to mismatch the green and blue cable if you are color blind.
Dec 22, 2009 | Panasonic PT-50DL54 50" Rear Projection...
No Color Picture
Are you using the Red/Green/Blue cables or are you using the Red/Yellow/White?
Also make sure you are matching the colors up correctly. If you find that you only have two of the three RYW, try hooking it up to another AV jack on the side or front of the new TV. If you are using the RGB, sometimes in low light settings, the blue and green are easily mixed up.
Another thing you might want to try is changing your settings on your tv for NTSC as it might be set up for PAL.
Dec 15, 2009 | Nintendo Wii Console
All of our photos end with a magenta to purplish hue. We are using Canon inks, and followed standard trouble-shooting procedures; checked proper placement, printer alignment, deep cleaning. We are also...
Print a "test" page:
<HTML><BODY>
<FONT COLOR="#FF0000"> RED TEXT </FONT><HR>
<FONT COLOR="#00FF00"> GREEN TEXT </FONT><HR>
<FONT COLOR="#0000FF"> BLUE TEXT </FONT><HR>
<FONT COLOR="#FFFF00"> MIX RED & GREEN INK </FONT><HR>
<FONT COLOR="#FF00FF"> MIX RED & BLUE INK </FONT><HR>
<FONT COLOR="#00FFFF"> MIX GREEN & BLUE INK </FONT><HR>
</BODY>
</HTML>
and see if the printed colors are "true" to what you see on the computer-screen.
Nov 23, 2009 | Canon I960 InkJet Photo Printer
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
Jan 05, 2008 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
