Question about Yamaha RX-V863 Receiver
Video Monitor Hi. I cannot get any video out of the "Video Monitor" RCA jack of my RX-V863. Is there a simple check list?
  • Yamaha Master
  • 1,114 Answers
Check the Setup menu. Goto Video setup and make sure "conversion" is on. Another way to test is to hook up DVD, Cable Box etc. using only the standard "composite" video output (yellow). It should pass thru monitor out regardless of the internal setting on the receiver. Most electronics now are hooked up with Component, HDMI, or DVI which would require the receiver to downconvert the signal in order for you to view it on another video source. Hope this helps. If you still have a problem, list all your equipment model #s and I can troubleshoot more accurately.
Posted on May 24, 2009
Hi I have a yamaha rx-v863 there is no sound comming out of the 2 front speaker, heven if i put it on 2 chanel, what shoul I do? Thanks Beb
Crack the manual open and do the speaker tones test to verify the hardware. Come back with the results.
Aug 15, 2011 | Yamaha RX-V863 Receiver
I have an RX-V863 and sometimes when I turn the system on with my Harmony remote the receiver continually blinks like it is not getting a good signal and I have to turn the receiver off then back on to get...
Problem seems in standby power supply board and most likely leaky capacitor(s) or cold/ dry solder connections in that circuit board. It is hardware problem and does not look like speaker wires or connection cables fault.
Hope this will help.
Mar 22, 2011 | Yamaha RX-V863 Receiver
How do I connect my Yamaha RX-V463 surround sound system to an analog tv? The tv only has the three RCA jacks for audio and video. the RX-V463 has many jacks, and the manual is no help. the manual does...
Actually, the Quick Start Guide on page 6 of the manual shows the TV connection.
Consider that the TV is simply a visual element in your entertainment system and the rest will sound easy.
Run a single RCA cable from the receiver to the TV's Video IN so you can use its menus and view whatever video comes into the receiver.
Manage whatever audio you want to hear in HI-FI directly from its source to the receiver and NOT washed through the inferior audio electronics and speakers of the TV.
Jul 18, 2010 | Yamaha RX-V463 Receiver
I want to use a 4 ohm center speaker on the RX-V863. Will that work OK? The two main speakers are both 4 ohm.
It should not be a problem. Most speakers nowdays are 4 ohms and since your mains are 4 ohms there should not be a problem. Your manual should stipulate the impedance and it should also be on the amplifier somewhere. Let me know if you need more help.
Thanks for using FixYa
Feb 19, 2010 | Yamaha RX-V863 Receiver
My reciever has no sound. everything else still works but it just won't put out any sound at all. yamaha RX-V863 7.1 channel. less than 6 months old.
Check your "A/B" speaker selector switch on the front panel of the receiver, if they are on, you will see "A" "B" or"AB" on the front display. If they are on, You need to have the receiver serviced. Just a note, Yamaha's rarely have an output problem! Hope this helps
Jan 09, 2010 | Yamaha RX-V863 Receiver
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Nov 26, 2009 | Yamaha RX-V863 Receiver
No video from RX-V863
This reciever might not upconvert component or composite to hdmi, which means if you have anything but hdmi hooked up you will not see it. Check your manual for what all the reciver will ouput.
Jul 24, 2009 | Yamaha RX-V863 Receiver
Conecting plasma to receiver using hdmi lead
if you receiver has a Aux function an is still unused try to hook your playstation audio rca up to it directly it will work either way, Hope thats what you mean, An Hope it works
Oct 23, 2008 | Yamaha RX-V863 Receiver
Yamaha RX-V863 Receiver Logo
105 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
