Posted on Jul 22, 2011
Pixma MP150 Waste ink absorber is almost full.
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Jul 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
4713
Points
91
I had a similar issue recently with an Epson printer. I solved it by unplugging all cables and removing the outer casing (there were several screws, easily removed with a philips head screwdriver). You can then get at the waste ink sponges. Caution - wear gloves! dealing with printer ink is messy! Carefully remove the sponges and wash them out. Allow to dry fully before putting back into the printer.
Hope this helps!
Tom
2answers
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
4helpful
Hi
Do you need to reset the counter in MP150?
Anyways remember that you need to repalce the absorbers also later. Follow the below procedure and you can start using the printer again.
PROCEDURE I. Enter Service Mode:
  • Plug in power cable
  • Hold down STOP/RESET button
  • Hold down POWER button
  • Release STOP/RESET
  • Press STOP/RESET twice in a row
II.Execute Waste Ink Counter Reset Operation:
  • Press STOP/RESET button 4 times (Indicator lamp will blink alternately Orange/Green each time the button is pressed)
  • Turn off the printer by pressing POWER button (wait until the printer is completely OFF)
When you turn on the printer,waste ink absorber full error is cleared and the printer work normally.
Original source: http://www.printerclinic.com/reset-waste-ink-counter-canon-pixma-mp150/#ixzz1SaAjTfWu
2helpful
The waste ink absorber is full
To reset your Canon IP1000 just simply pull out power cord then press-hold power button, while holding power button insert back power cord. You will notice that the power button indicator lights up upon inserting power cord. then you may release power button and start printer. That will solve your "The waste ink absorber is full" message.
Downside is: you may have to do this frequently if your printer looses power. You will understand what i mean.
3helpful
Absober waste ink is full. Pls help. error code
you need to replace the absorber waste ink pad and service the printer
9helpful
Our Canon Pixma MP150 is showing an error message E5 and previously E3. Can you tell me what these mean please.
here are the error codes for your printer
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
5helpful
Printer flashing E8
E8 means Waste ink absorber full, or platen waste ink absorber full so reset ink also check the waste ink pad and clean
4helpful
Error 8
Dear sir your problem is or E8 mean
4helpful
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Ink absorber full
you have to reset the waste ink counter of the printer, for this download the software like IP tools, then reset it,
like it or not please rate it
ERROR MESSAGE 2
How do I change the ink cartridge for the Canon Pixma 150
k24674
ADMIN Andrew
ADMIN Andrew
