Question about Intel D865GBF Motherboard
Hi my motherboard restarts by itself
I have this problem since i updated my bios with the latest version
    Problem Solver:
  • 8 Answers
Possibly ur snps [power unit] got damaged u better replace it with a new one...
Posted on Sep 02, 2008
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
Where I can find last BIOS version for my P5VD2-NVM/S?
Click on Start and then Run.
In the text box in the Run window, type msinfo32 and click OK. This will open the System Information program.
When System Information first opens, it defaults to the System Summary, a short list with some of the most important information about your computer system listed.
On the right side of the program, locate the BIOS Version/Date entry.
This field contains the BIOS version that is currently running on your motherboard.
This field may also contain additional information such as the BIOS date, BIOS manufacturer, motherboard manufacturer and the motherboard model number.
Note: If the BIOS date is shown, it can be useful in determining the current BIOS version from a motherboard manufacturer's website if the version is not clear here.
Write down your existing BIOS settings so you can restore them after you've flashed the new BIOS firmware.
Determine the correct BIOS firmware that you need for your computer.
Check your computer manufacturer's website for this information.
If you have a custom-built system, check the motherboard manufacturer's website for the latest BIOS firmware.
Download the latest BIOS firmware specific to your computer.
Some manufacturers provide custom software that initiates the update through your operating system; others provide a third-party application that allows you to flash the BIOS through DOS.
Run the installer or executable file that you downloaded.
Alternately, if the BIOS firmware update is handled via your operating system, simply click "Update," "Write," "Confirm" or a similarly-named button.
If you are prompted for an installation CD, insert the media into your disc drive.
If the CD contains an "autoexec.bat" file, the BIOS will flash automatically when you restart the computer.
While the BIOS flashing procedure varies, nearly all manufacturers provide detailed instructions for completing the task.
Turn off your computer.
Wait about one minute and then reboot.
On some systems, the flash update will restart your computer automatically.
As your computer reboots, go immediately into the BIOS setup menu and look for an option to "Restore Defaults" or "Load Fail-Safe Defaults."
This will be on the main page or the last page of a tabbed menu.
Navigate using the arrow keys on your keyboard and follow all on-screen instructions.
When finished, save your new settings and then exit BIOS.
Your computer will load the operating system.
http://www.wimsbios.com/recommend/biosagent/ibelowmenu
hope this helps
Sep 18, 2012 | Computers & Internet
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
HI i install DG33bu bios update my soung is goan . please help in resting the bios version
after bios update u need latest drivers....
download the latest audio drivers from the site wer u downloaded ur bios update...
also check ur default playback device is speaker and not headphones
assuming u use windows 7
May 10, 2011 | Intel DG33BU Motherboard
Where can I find info to setup bios. also how do I upgrade bios
For this you need to know the exact model of your motherboard. Your current BIOS firmware version can be seen in the BIOS setup window itself ( Press DEL key during your system startup to enter into BIOS screen)
Your motherboard should have Flash BIOS so as to upgrade its firmware. All latest motherboards will have this type only. Goto your motherboard manufacturer website and search for latest BIOS firmware for your exact model. There itself you can find the utility required for BIOS. download that utility and using which you can update your firmware. Please do update your BIOS only if it is required.
I hopt his is helpful to you
Dec 31, 2009 | Computers & Internet
I can't configurate my bios version k7s41gx. Please help.
you cant configure your bios version thats something thats programmed into the EPROM or flash memory on the motherboard you can update it using the utility and latest firmware from your motherboard manufacturers website to add functionality or features to your motherboard ie so you can use larger hard drives or that sort of thing.
Other then that the version of your bios is just to let you know what version you have so you can establish if you need to update it or if its the latest version or not.
Apr 21, 2009 | Network Associates Computers & Internet
CPU not support found !!
you need to change settings in your bios for the type of cpu you changed to
Or reset your bios to default it could still be set up for old cpu
Aug 02, 2008 | ASUS M2N-MX Motherboard
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
Some Help Please...
You can try picking up a BIOS for a PC Chips M810DLU from the company's website here. You need to remember all the usual precautions when flashing.
Please do not expect much improvement or stability when overclocking a PCChip motherboard.
Good luck and kind regards.
Nov 04, 2007 | PC Chips M810DLU (M810DLUV75C) Motherboard
Intel D865GBF Motherboard Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
