Whirlpool Washer Stopped spinning
I have a Whirlpool LSB6200KQ0 washer. It just stopped spining for rinse and spin cycle. It also makes a loud weird noise when it tries to spin. Can you please give me any tips?
  • 641 Answers
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
Posted on Jun 07, 2006
  • 213 Answers
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Posted on Nov 21, 2007
  • 351 Answers
SOURCE: Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Posted on Mar 09, 2008
SOURCE: washer not spining
I took the bottom panel off the washer. I don't know what i'm looking for?? Help!! The washer won't spin. the belt and motor are ok..
Posted on Sep 14, 2008
  • 1028 Answers
SOURCE: WASHER IS NOT RINSING OR SPINNING
probably a bad lid switch ckd the area on right side of lid opening switch mounting screws can break out allowing switch to drop our of postion..switch lever could be broke or just not going far enough down to engage
Posted on Sep 18, 2008
Washer making whining noise rinse cycle
Possibly a worn drive belt, or it needs tensioning.
Jan 06, 2018 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Our washer just stopped working. It was on the
Unplug your washer for 10 minutes, and retest. If this does not reset your spin cycle you will have to let me know what brand and model this is. Appliance Specialists
Dec 10, 2009 | Whirlpool Washing Machines
Washer stopped before spin and rinse cycle.
you nead to bay pas the door switch. orb replace
it.
Nov 17, 2009 | Washing Machines
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
223 people viewed this question
Top Washing Machines Experts
