Question about Canon Cameras
I have a Canon CB-5L Battery Chargerthat has just gone Faulty. There is 230 Volts going into the charger, but there is NO DC 8.4 Volt 1.2 Ampere Output between the Plus and Minus Pins. How can I open it to have a look at it to see what is wrong? I have a reasonable knowledge of Electronic and Radio Repairs and I am sure that I could repair it after checking it with my Ohm/Volt/Amp Meter. However, it seems designed NOT TO BE OPENED for Servicing!!! Many Thanks, Brendan Kilbride.
  • 203 Answers
SOURCE: using battery charger overseas
it's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
Posted on Jun 07, 2008
SOURCE: Not charging
Here is how you fix the problem (without using a 9V battery!).
The battery doesn't charge because it's been fully discharged.
What you do is you put the camera into the cradle. Now you see that the Red LED comes on solid for a while. It's charging for a few seconds. Then it starts blinking. When it does that - TAKE THE CAMERA OUT of the cradle.
Now put the camera back and repeat. Do this six or eight times. Each time what's happening is that the battery is getting a tiny bit of charge. After 8 times the LED will come on red and stay solid red.
Bingo, no problem!
Posted on Jun 15, 2008
sumthin
  • 71 Answers
SOURCE: FE-230 Failure to come on
Hi Gary
Is the camera under warranty and registered with Olympus? If not registered, make sure you do that online first. It also extends your warranty to 13 months. If no receipt, It was a gift.
You most likely have a bad lens assembly (was it dropped?) or microprocessor. Here's your link...
Olympususamerica.com
Consumer division, customer service 1-800-622-6372 M-F 8 to 7 EST
Outstanding people to deal with
Hope I could be of some help. Regards, Paul
Posted on Aug 16, 2008
SOURCE: Vivitar ViviCam 8600s----I need a charger or docking station for this camera
A friend traveling through Hong Kong found one in a random electronics market; it works perfectly! I have a camera again!
Posted on Feb 20, 2009
sparky1500
  • 1066 Answers
SOURCE: Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
Posted on Mar 29, 2009
Battery and or charger won't work. Charged a full 18 hrs. Help
Possible suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
Nov 27, 2015 | Motorcycles
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
Audiovox schematics
If the player has a rechargeable battery older than 2 years, it is probably going to need to be replaced. Look at the volts-Ampere-hours rating, and replace with same volts more ampere-hours AH rating.
Aug 01, 2014 | Audiovox D1998 Player
I have one i2! which I used to use with an iPod, but now I tried to use it with an iPhone and with an iPad, and the USB doesn't show the charging capability any more. Does the i2! not work with iPhone and...
All iPhones and iPad's charge with a USB cable. Everybody knows that. What moest people don't know is that it's a bit more technical then that. Every USB port has an electrical voltage of 5 Volts. The voltage of a electrical socket is in Europe 230 or 240 Volts, in America it is (i think) 110 Volts. In a car there is a voltage of 12 Volt. An adapter (charger) will convert a higher voltage to the 5Volt needed for the USB-port. Now i did talk about voltage, but not about current. The current is the amount of electricity running through the device. An old ipod can charge with a current of about 700mA (milli Ampere). Newer iPod's and all iPhone's need 1000mA (or 1A = 1 Ampere). An iPad needs even more. The largest component inside an iPad is the battery. It would take too long to charge this large battery at 1000mA (1A) so it needs 2100mA (2,1 A). If you check the label or the printed information on your FM-transmitter you will see the Ampere rate will we too low, and that's why your other devices won't charge. I suggest you to go to a store and buy a compatible charger or FM-transmitter.
Aug 19, 2013 | Aerielle FMT300IP Model i2i Universal FM...
I bought a new 9.6V NiCd pack battery but after I charged it the car run only 1 min or less. I measured the pack and it shows only 4V. I'd appreciate your comments.
  • A 9.6 volt battery should read around 10 volts or higher after a full charge. If your battery only worked for a minute and has 4 volts then you received a bad battery and it should be returned for a properly functioning battery. Or your battery charger is not charging properly.
  • It's simple enough to test. Get a volt meter and set it to DCV (DC Volts). Now turn the charger on as if you were going to charge the battery. Now place the positive terminal in the positive side of the connector on the charger. Do the same with the negative side. If it does not read AT LEAST 9.6 Volts (probably more like 10.2 - 10.5 Volts) then the charger is not putting out enough to charge the battery. A new battery charger will be needed.
  • If the volt meter reads anything lower than 9.6 then the battery is bad and you will want to get it exchanged.
  • Hope this helps and thank you for using FixYa.
regards, Tony
Jul 25, 2011 | Jada Remote Control Speed Racer Mach 5 Car...
Can I charge a Canon Powershot sd 870 is with the usb port?
No. The NB-5L battery pack must be charged using the CB-2LX or CB-2LXE charger or compatible.
Jun 08, 2011 | Canon PowerShot SD880 IS IXUS 870 IS...
Versapak battery will not hold charge
If it is an old battery (3 plus years) it probably needs to be replaced. The other failure point is the charger. That can be checked with a volt meter. should be about 4 volts for each battery in the system. 1 battery 4 v, 2 batteries 8 v. Depending on the system it maybe either ac or dc. Try both with your volt metter.
Amazon seems to have the least expensive replacements.
Search for Black & Decker VP143 Versapak Gold Twin Pack.
Jun 19, 2010 | Black & Decker 3.6 Volt VersaPak® Battery...
Battery #1 terminal lights red and stays red.
Disconnect the - lead from that battery, Repower the charger. The LED should be green. If it stays RED, charger defective.
Reconnect the - lead to the battery, measure voltage when charger is on. Should be between 11.5 and 13 volts. If OK, replace the battery. If lower than 11.5, check for charger cable connections OR for a connected load ( power drawing ) of more than 10 amps.
Sep 20, 2017 | Guest 2631a 30 Amp Battery Charger
My DC16 will start and then stop. I have to take
My DC16 also had charging problems. I called Dyson and they sent a new charger. The old charger only produced 23.6 volts DC, not the rated 28 volts DC. The new charger has a thicker round wire and produces 28.1 volts DC. Put a volt meter on your charger terminals and see if it is producing enough voltage to fully charge the battery, 28 volt DC. If not you need a new charger.
Jan 31, 2010 | Dyson DC16 Root 6 Bagless Handheld...
The voltage for charging and plug-in power, cobra hh35?
the voltage for the charging is 12 volts dc the charger is a 110 volt dc 12 volt to the radio if you lost your charger you can get a aftermarket at any radio shack store just be sure you take the walkie with you when you go so they can match up the rdio plug end.
Mar 11, 2009 | Cobra HH 38 WX 40-Channels Handheld CB...
Cameras Logo
316 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
