Question about LG Heating & Cooling
LG split system code "C6" appeared. Unit will not turn on?
  • doms1273 Aug 29, 2008
    Would you think resetting the unit would help?
    If so where is the reset button on LG splits?
  • doms1273 Aug 31, 2008
    Thanks for the help so far... tried to reset it, but it just keeps tripping the circuit breaker. I will call the technician to come and have a look.
    Thanks again
  • 639 Answers
Friend,
Happy to assist you!
Perhaps a bad blower.
Sounds like an electronic failure you need a hands on diagnoses!
My words alone will not remedy the situation!
Do not wait to fix it next year to repair it!
The cost will be more then Bad Inflation!!!!!!!!!
You need to call service !!!!!!!!!!!!!
LET ME KNOW WHAT HAPPENS???
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 29, 2008
  • Neil
    Neil Aug 29, 2008
    Friend,
    Turn off the power from the circuit breaker and wait 3 minutes before powering up. This should reset the system!
    But I think it is not a reset problem
C6 error code
Check capistor and gas leaking
Dec 02, 2013 | LG LSC121PMA Split System Air Conditioner
ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL NUMBER LSZ244VM4
The first thing i'll say is you will need to get it repaired by a technician and i strongly recommend you not to do it by urself.
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit.
Goodluck..
Mar 08, 2008 | LG LSC183VMA Split System Air Conditioner
My LG split system air conditioner shows C6 in the display of the unit. I can't do anything to get it to function now and even when I swicth the mains power off C6 is still shown. What do I need to do and...
C6-Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor.Thanks, helpful?
Feb 04, 2011 | LG Heating & Cooling
Our airconditioner has the code C6 on it. It has cut out and displayed that code. We were instructed to turn it off at the power board and turn it back on, which we did. It went back on again and tried to...
I previously asked you, if the C6 appear on the unit or on the hand held remote. I contacted a friend of mine who is a service technician for the LG Split System units and he advised that it's an error code that can only be solved by a LG trained service tech or LG itself. It may have been caused by a power surge, which may have caused some damage to the circuit board.
Sorry I couldn't be of more help.
Feb 03, 2011 | LG LA185HV Split System Air Conditioner
Air con unit saying 'C6"
According to the service manuals:
6 is:
Excessive current at inverter
DC power circuit
so the unit shouldnt run?!?
The fault is also coming up as:
indoor unit coil sensor faulty
source:
http://www.mylg.co.uk/data%20for%20site/LG%20Fault%20Codes%20for%20SMS%20%2807%20Sept%29.pdf
all the best
Jul 05, 2010 | LG LSC183VMA Split System Air Conditioner
Head unit on our split system has code C6 showing. what does this mean
what make is your system and what is your indoor and outdoor model number?
Nov 13, 2009 | LG Heating & Cooling
Displaying "Co" code, and running when turned off with the remote
It sounds like you have lost communication between the indoor and outdoor units. This can be one of two things. Either the connection indoor or outdoor is loose or bad, or a rat may have eaten the cable in cieling.
Feb 28, 2009 | LG Art Cool LA121HNP Split System Air...
We have an LG SQ/SR/ST chassis inverter model air conditioner....the airconditioner keeps stopping with the screen display...C6 appearing. When we turn it off at the mains it seems to reboot it for a while...
i can figure out what model a/c you have from this discription/ is this a lg floor mod. or window model or lg duckless split system
one comon problem causing faut is dirty filter or condensor but hard to figure if i cant place the unit disciption.
Oct 20, 2008 | LG Heating & Cooling
Heating & Cooling Logo
140 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
