Question about PC Chips M789CG (M789CGVIA2000) Motherboard
Disable Display ?
I have the M789cg motherboard and i have just picked up a new graphics card (new to me that is).
I was hoping for a simple PnP...but unfortunately not.
I have popped in the card, i get to windows screen and the computer reboots :(
I can get to safe mode and safe mode with networking, So i went straight to the nvidia website and downloaded the drivers....Once downloaded and the installshield start running i get an error..."The Nvidia setup program could not locate any drivers that are compatible with your current hardware"
I am assuming that the software is looking at the built in vga adaptor, because windows still does in the " my computer" "display and drivers "
Anyway to the point.
Im sitting here with the monitor plugged into the new card and see everything on screen in network safe mode.......How can i disable the built in graphics adaptor on the motherboard.
Incidentally, I know the motherboard and card are not particularly great but that computer is only for playing one game for my son online :-)
Many thanks for your assistance
  • 2 more comments
  • dalov Aug 29, 2008
    Thank you for the fast replies :-)
    Unfortunatley there is no option of " peripherals" in bios, nor is there an option to disable vga or onboard graphics.
    PCI i have enabled but the computer is still rebooting at the login screen for windows.
    Would there be jumpers that could be moved / removed on this motherboard to diable the onboard graphics ?
    Again, many thanks :-)
  • Anonymous Oct 31, 2008
    Pls. help me wit dis..
    i need a AGV driver for M789CG.PLS.
    Kindly send it to my email: Tyarlee_09@yahoo.con
  • Aasym_C Dec 10, 2008
    yes
  • Roberta Smith
    Roberta Smith May 11, 2010
    what slot did you plug the video card into ?... it sounds like you need to boot to that before it tries onboard video. the setting is in your bios. some motherboards do not allow you to shut off the onboard video either.
    Robert
    Brigadier General:
  • 5,158 Answers
I'll leave this to you then sandrew
Robert
Posted on Aug 29, 2008
    President:
  • 2,961 Answers
You need tp press F2 or Del on startup and enter the bios and look in the peripherals menu, if not there, just look for VGA or onboard graphics and select dissable, but remember there will be a line in the bios to enable the PCI or AGP card as the primary graphics controller, save settings and exit for a restart.
No video signal, tried a new Graphic card same error msg FF
Check your bios settings for the graphic.
Try the onboard VGA graphic first.
Here you can download manual and drivers for your product:
http://www.epox.com/product.asp?id=EP-8HDA5plus
Hope this will help you.
Mar 15, 2011 | EPoX EP-8HDA5+ Motherboard
No display
install external Video card and disable the internal on the Bios
Aug 17, 2010 | Intel D845GVSR Motherboard
My Matrox rtx100 graphic is not dected by the computer.I could not install the driver
Hi!
Try uninstalling first display adapter that is currently installed form your device manager...how?...
1. On My Computer, right click and select properties.
2. Select Hardware tab, and click Device Manager.
3. On the list of device manager, click View menu and select Devices by type
4. Double click Display Adapters, to display the list of connected graphics adapter.
5. Disable the graphics adapter listed, by right clicking of the file name and select uninstall.
6. Now close any program and shutdown your computer..
7 Connect your video card to the motherboard and turn on your computer. Your computer will run its Add New Hardware Device , just be ready with your driver files..
I hope that will make your video card work with your motherboard
Much appreciated if you rate this solution..thanks.
May 24, 2010 | Matrox RTX100 Xtreme Pro Suite Graphic...
Display problem
Hi there
try going into the bios settings and disable the on board graphics and change it to PCI or PCI Express.
You may have to plug the monitor into the on-board VGA port to do this, once done shut the computer down and change graphics port, then restart the pc, your problem should now be solved
Good luck and kind regards
Jan 06, 2009 | ASUS P4SGX-MX Motherboard
Onboard graphics
it will be there somewhere, look for similair to graphics/hardware, make sure you open up the menus sub menus
Aug 29, 2008 | PC Chips M789CG (M789CGVIA2000)...
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
Radeon X1650
before doing anything.. What do you mean you get no blank monitor? Do you see anything at all? Do you see the POST running? Also, when you put in the AGP, did you plug your monitor into the new card? Or are you trying to boot from the old intergrated one?
You can change your graphics input in the BIOS from integrated to AGP (after putting in the new card). But, It should pick it up fine without changing it. And if it doesn't work after doing so, your motherboard may keep the settings, and then a deeper problem arises..
Apr 16, 2008 | Sapphire RADEON X1950Pro 512MB Graphic...
Motherboard problem
Hiw can u say's its display problem,Have u checked the signals on k/b ?
If not check the Num lock status in keyboard. Press the Num lock key ,if the light glows and stands for sometime display is ok,but ur vga adapter is the problem.
Otherwise problem maybe with m/b or psu.
Pl check it.
Regards.
Was this soultion useful?give the apppriciation by rating it.
Apr 04, 2008 | ASUS P5K-V - Motherboard - ATX - iG33 -...
Disabling the onboard graphics for this motherboard
hi, go to system bios, i think in the second options check out for primary display , you will have options for add on, or onboard, change it to add on, or there is also an option to disable the primary display somewhere there, browse the bios around , you will find either of it. let me know
Dec 16, 2007 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
PC Chips M789CG (M789CGVIA2000) Motherboard Logo
221 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
